Author Topic: NTA - for the second fukking time, stop calling us!  (Read 13930 times)
Re: NTA - for the second fukking time, stop calling us!
« Reply #60 on: July 15, 2020, 01:50:21 pm »
Solid connection is probably better anyway... presumably the oven would have to be pulled out to get at the connections hence the need for a hose.
« Reply #61 on: July 15, 2020, 02:41:42 pm »
We changed the gas oven to electric but we wanted to keep the gas hob(replaced also with a stainless brushed steel unit)...the wiring for the oven was always there so that was an easy install other than having to employ my kitchen fitting skills to make a unit to facilitate the narrower and shorter electric oven,when fitting the gas oven all those years ago when we moved in i had to remove the unit that was there to facilitate rails that the gas oven slid in and sat on,unfortunately it wasn't a straightforward job...are they ever...
« Reply #62 on: July 15, 2020, 02:47:48 pm »
It's never straightforward! Provided there's a 32 Amp MCB on the cooker circuit - there usually is - a nice new induction hob would be a piece of piss to install... but don't get her one that's restricted to c.13 Amps, they're kinda self-defeating.
« Reply #63 on: July 15, 2020, 02:59:53 pm »
The cooker switch and wiring was there,connecting it was the easy bit....the fukin around to facilitate it was the hard work,
I won't be mentioning induction hobs to her but thanks for your help!!
« Reply #64 on: July 15, 2020, 03:20:53 pm »
Ah go on... tell her the aul one across the road has one...
« Reply #65 on: July 15, 2020, 03:30:13 pm »
The oul wan across the road doesn't have one.
« Reply #66 on: July 15, 2020, 03:36:43 pm »
That's your story and you're sticking to it, I guess.
« Reply #67 on: July 15, 2020, 03:38:28 pm »
Yes...m'lord.
« Reply #68 on: July 15, 2020, 04:19:23 pm »
Always had a Gas hob but switched to an induction one when we changed the kitchen, same adjustability as the gas but so much cleaner, had to buy a whole new set of pots though
« Reply #69 on: July 15, 2020, 04:24:31 pm »
What if any extra electrical work needed to be done to facilitate an induction hob?....purely to satisfy my curiosity mind.
« Reply #70 on: July 15, 2020, 04:47:02 pm »
Same as the oven... wire it into the cooker switch. Just make sure the cooker circuit is on a 32 Amp MCB (most likely is) and don't buy one that restricts it's total power to something like 13 Amps, they're designed to be plugged into a normal socket and pretty much defeat the purpose of having the power of induction. Expect to pay €400+ for a 4 ring or a bit more for 5 rings.
Now go and tell Mrs. Hal that TOO has one!
« Reply #71 on: July 15, 2020, 04:53:12 pm »
The only circumstance in which I'd avoid induction is if you have a mains (water) electric shower (8KW+) and a 63 Amp consumer unit (63A = rating of main fuse)... in that scenario you could be stretching the limit on the consumer unit and find that taking a shower while the Hob, Oven and maybe a washing machine / dryer / kettle are on will pop the main fuse... at least do the math first.
« Reply #72 on: July 15, 2020, 04:55:04 pm »
I did notice there's also a socket down low at the back of the oven.
And we do have a Triton T90 shower.
« Reply #73 on: July 15, 2020, 05:01:20 pm »
mmmm... stick with gas probably if the consumer unit is 63 Amp. Shower's probably 9KW, off the top of my head that's around 35 Amps, more than half capacity gone for a start. If the oven's taking 12 and a dryer is taking 10 that leaves fuck all before the main fuse pops... There's sites that can do the math for you, definitely worth a look before you leap!
« Reply #74 on: July 15, 2020, 05:05:27 pm »
I won't be leaping...therefore looking is a waste of my time.
