Author Topic: Charge ........  (Read 5943 times)
Re: Charge ........
« Reply #15 on: July 14, 2022, 02:17:25 pm »
Is Climate Change the same as Global warming ?What ever happened to Acid Rain .Its a Natural Phenomenon the Jet Stream Moves all the time .Big Dommos Great Great ancestor .Worked for Pharo Block Masons in Egypt hung around the Flats with Cleo and Sharon from the Gaffs near the Flats .Anyway one day he was walking his Jackal and bumped into Phinney the Elder who was complaining about the weather .He said if this Jet stream keeps moving the lands will turn to desert and the Egyptian Civilization will Fall .Sothern Europe is becoming uninhabitable for the same reason the Jet Stream is moving .Its a Natural Phenomenon not Man Made .Man is just cashing in selling Snake Oil .Stand outside in your Garden feel the heat radiating back into space from your driveway now multiply that by billions of miles or Roads Paths Roofs all reflecting heat back into space .The earth is covered in concrete cannot absorb the heat naturally causes huge radiation .Look at the amount of the earth covered in concrete and the increase in earths temperature and see if they match up .
« Last Edit: July 14, 2022, 02:31:44 pm by John m »
Re: Charge ........
« Reply #16 on: July 14, 2022, 02:44:57 pm »
@ Watty I was thinking of you when I remarked about the loss of Productivity .How many hours a week do you spend recharging .If you put a value on that time does Electricity work out any cheaper than Dirty Diesel ?
I do a mix of home (3 pin) and external charging at the moment. So about 70 mins a week at an external charger. How long do you spend waiting on the Heuston rank?
IMHO, it's impossible to price this time since we spend a huge amount of our day waiting for a fare. Just ask the keshies how much time they spend driving!
I don't do it myself but some leave the apps on so if they get a job they just unplug and away they go...
BTW the average person would probably charge once a week, at home, while they're sleeping.
Assuming the average driver does eight hours a day, or four hours a night, surely a type one or type two home charger would be sufficient?
Everyone ignores the amount of time the taxi is idle in the garden or outside the flat. A cosy could be the answer.
Re: Charge ........
« Reply #17 on: July 14, 2022, 05:44:40 pm »
If we assume most EVs have a 60kwH battery, then the house wall charger will pump out 6-7kW/hr and the 3 pin plug will do 2-3kW/hr.  I need (very approx) 24kWh for my shift so you can do the maths from that.
The downside of the 3 pin method (granny charger) is that you're pumping ~12 Amps through the plug for hours at a time.  If your plug (&/or extension cable) is not up to it, it could melt the socket, the plug, the cable and I guess set the house on fire!  Having said that, plenty of people are happy to do that.  I only do it while I'm awake otherwise I think I'd probably be able to 3pin home charge all the time (3kWh x 8 hrs = 24kWh).  Realistically though, I don't think your average house wiring/sockets are designed for that sort of continuous ampage.  Hence, my split between home charging and external charging.
Re: Charge ........
« Reply #18 on: July 14, 2022, 05:49:15 pm »
Yes.
Global Warning was the first catchphrase but too many people, myself included, thought "bring it on, we all want hot summers!"  So they changed it to Climate Change to better reinforce what's we're doing to the planet.
Re: Charge ........
« Reply #19 on: July 15, 2022, 12:18:40 pm »
Wont be any change….left soon!    As Carl Sagan said about Climate Change….The reason that steps are not taken to modify the changes are because, we say…why should we have to pay for something that may happen in the future. ::cheers
Re: Charge ........
« Reply #20 on: July 15, 2022, 12:29:20 pm »
@john m, JCB have hydrogen combustion engines in development now to go on sale in around 2030 for all their heavy equipment. They said making the equipment electric in any form even hydrogen electric would push the price from around 350,000 to over 700,000 pounds for an excavator. Plus it saves outside jobs in the manufacturer of internal combustion engine parts for the factory and mechanics as well, as all parts and materials are got in the UK and Europe. Plus the engine's can be retrofitted to diesel powered machines in the future if needed.
Offline cruiser
Re: Charge ........
« Reply #21 on: July 16, 2022, 12:34:38 am »
Bring back breast feeding the shovel gangs
Re: Charge ........
« Reply #22 on: August 03, 2022, 11:17:27 am »
Im a bit slow on that one??
 Give us a clue
Offline cruiser
Re: Charge ........
« Reply #23 on: September 12, 2022, 09:51:16 pm »
Before mechanical diggers  came along all roadworks hole digging were done by jackhammer and crew with shovels.
While on break from shoveling they used to lean on shovel with the top of handle against their chest  ( breast feeding )
Re: Charge ........
« Reply #24 on: September 13, 2022, 12:01:12 am »
Should our electricity bills be called The Charge of the Light Brigade?
Re: Charge ........
« Reply #25 on: September 13, 2022, 08:26:13 am »
 Are any of our so called reps in Talks with government or Dep of Transport or Environment to get a one off Fuel Subsidy Grant for us in line with Grants proposed for other Small businesses ?
Re: Charge ........
« Reply #26 on: September 13, 2022, 11:20:34 am »
Home chargers are grand if you live in a house.
Most EVs have a 7 year battery:
Car value plummets after 2-4 years
Brand new EV taxi effectively has a 7 year licence max.
ID4 tyres €300+ per corner .
EVs would need to be traded in after 2-3 years imho.
Re: Charge ........
« Reply #27 on: September 13, 2022, 11:59:49 am »
€300 a tyre..that's crazy.I hate paying €115 for mine.
Re: Charge ........
« Reply #28 on: September 13, 2022, 12:03:41 pm »
Read somewhere Eamo the Scallion wants to put a 20Euro recycling charge on Tyres to be paid at time of purchase .Seems that rubber erosion is putting particles into the atmosphere .How much recycling charge on bike tyres or tubes ? Save the Rubber Plants they are People Too.? They are also concerned about brake pad erosion another TAX ?They are going to tax motorists off the roads they spent hundreds of Billions to build .
Re: Charge ........
« Reply #29 on: September 13, 2022, 12:12:30 pm »
So I`m told , might be horseshit though.
