Author Topic: Recommend a Product .  (Read 10694 times)
Re: Recommend a Product .
« Reply #30 on: December 24, 2024, 06:24:09 am »
... ...someone was talkin bout ther wheel was stuck an the nuts wer off tryin change a puncture......roll the spare wheel into the rim... ...
That's a good tip.  ::cheers
« Reply #31 on: December 24, 2024, 06:36:42 am »
Stuff to make your life easier ...
... This stuff spray on Fabric seats to make them waterproof stops staining and gives you time to wipe up Piss or Puke
..https://www.screwfix.ie/p/fabsil-universal-protector-water-repellent-spray-400ml/25815?tc=CI4&gclid=CjwKCAjwkeqkBhAnEiwA5U-uM7aoI2XdnRDFCdixNey4OweCYR0DW5US2eL0xj08xgiDLVKREqByJBoCc6sQAvD_BwE&gclsrc=aw.ds
I intend to buy this Fabsil product John m, but how long does it take to dry properly in wintertime ?
And how many 400ml cans would I need fer just the upper back seat (not lower as it's leatherette covered) and the front passenger seat in full ?
« Reply #32 on: December 24, 2024, 06:40:38 am »
Gonna buy a small hydraulic jack as the new heap doesn't have a spare, ....
Did you buy one Hal ?
Which one ?
and is it any good ?
« Reply #33 on: December 24, 2024, 06:42:38 am »
...... also went mad and carry a small hydraulic jack, can't be bothered with those fiddly wrist breaking ones that come with most cars. ......
@ Harry, How are you finding that hydraulic jack ?
I'm thinking of getting one myself, but not sure which one to go fer ?
https://www.screwfix.ie/p/hilka-pro-craft-2-tonne-low-profile-trolley-jack/8827r
https://www.screwfix.ie/p/hilka-pro-craft-2-tonne-trolley-jack/7504g
« Reply #34 on: December 24, 2024, 06:52:21 am »
A little Tip I discovered all by meself last weekend when trying to reverse on a country lane by night in the rain, put on your rear Foglights, it doubles your rear vision.
« Reply #35 on: December 24, 2024, 08:43:30 am »
berry scented windscreen washer fluid.
when you get a smelly cunt onboard turn your air blower on pointed at your face and hit the washer fluid with the wipers. it picks up the scent from outside and blows a pleasant fragrance right in your face. a must have piece of kit.
https://www.halfords.ie/motoring/screenwash-de-icer/halfords--10-ready-to-use-berry-screenwash-5l-189107.html?_gl=1*o42hwl*_up*MQ..*_ga*OTUyNjcyMTYuMTczNTAyOTI2MQ..*_ga_G7H7ZEHZ8V*MTczNTAyOTI2MS4xLjEuMTczNTAyOTI4Mi4wLjAuMA..
« Reply #36 on: December 24, 2024, 09:15:39 am »
I don't like adding anything to my screen wash except plain water fer the simple reason that anything added only wears the rubber on the wiper blades.
PS. Thanks fer the Tip DMG on the Silicone WD40, it worked a treat on my schreeching side front window panels where the basic WD40 had failed after only 2 weeks fer many years.
I gave the wipers a clean too with it, but they were working fine before and after so nothing to report there.
« Reply #37 on: December 24, 2024, 06:05:18 pm »
it's perfectly safe for your rubbers i've been using it for years.
you don't add it to water you just fill the reservoir with it.
if you wipe your blades once a week with the silicone spray it'll keep them new and protected.
« Reply #38 on: December 24, 2024, 07:48:45 pm »
I got one similar to this...mine has a rubber protector on the bit that sits on the jack that meets the jacking point on the car...the handle is a rachet...the missus bought it as a birthday or Christmas gift last year!!
« Reply #39 on: December 24, 2024, 08:47:05 pm »
....  I got one similar to this...mine has a rubber protector on the bit that sits on the jack that meets the jacking point on the car...the handle is a rachet...the missus bought it as a birthday or Christmas gift last year!!
Is that not just a basic jack with a rachet handle ?
My bending and lifting days are coming to an end, I'm looking fer something real simple that almost jacks the car up by itself.
« Reply #40 on: December 24, 2024, 09:36:27 pm »
I use AXA Assist.
« Reply #41 on: December 25, 2024, 09:50:37 am »
Only used it once, great
« Reply #42 on: December 25, 2024, 01:50:45 pm »
It's probably the only bit of exercise I get Ken....but the ratchet handle makes short work of lifting it...although my jammer is a heavy bastid!!
« Reply #43 on: December 25, 2024, 06:20:27 pm »
Gonna buy a small hydraulic jack as the new heap doesn't have a spare,like MFH I carry a plug kit and also an extendable wheel brace with 17-19 and a 21-22 sockets....the new car has 21mm nuts,
I did look into buying a space save,shudda taken the 17" spacecsaver out of the Prius.
Should've gone to Spacesavers!! 8)
« Reply #44 on: December 25, 2024, 11:45:47 pm »
Thanks Hal and Harry.
I should have put it on me Santee list !  lol
