Author Topic: Hold strong Rc  (Read 17870 times)
Re: Hold strong Rc
« Reply #240 on: August 26, 2025, 03:55:31 am »
Oh, just an aside while I think of it, Ken... I asked about them menthol cigarettes that you like in Turkey last week... the tobacconist told me it's illegal to sell them over there... same as here.
Thanks fer thinking of my Menthol cigs Stephen, but after 5 years I have about come around to the everyday chore of useing the Menthol flavour card inserts in to each box.
Fer any other Menthol cigarette smokers I find the best flavour card is the Aroma Queen Menthol, they cost about 80 cent each and seemingly only available in Maxol service stations.
Re: Hold strong Rc
« Reply #241 on: August 26, 2025, 10:18:33 am »
The link is for Spain (I think) so why is it in English?  But I guess it's the same procedure
https://www.free-now.com/es-en/drive/taxi/driver-perks/
8% off car parts
Need to repair or maintain your vehicle? As a FREENOW driver, you get an exclusive 8% discount at AUTODOC, Europe’s top auto parts store. We're making it even easier to keep your taxi running smoothly.
Here's what you get:
• 8% off selected items
• No limit on how many times you use the code
• Only a €50 minimum spend
• New code every month
How to claim your discount:
1. Tap the button below to go to the AUTODOC page.
2. Copy your unique voucher code.
3. Add items to your basket.
4. Paste the code at checkout in the 'I have a promo code' section.
5. Complete your order.
Re: Hold strong Rc
« Reply #242 on: August 28, 2025, 04:36:07 pm »
On the Android app it's Menu -> Freenow Loyalty... Ken. Then if you scroll down, under Gold, you should see 10% off Vehicle Components. (6% for bronze, 8% for silver)... click on that and your discount code is there. I haven't read the T&Cs so I wouldn't screenshot it or anything like that, I assume it's intended for your personal use... but sure we could always say I ordered a bit for you or something if questions were asked!
I'm not going to bother ordering the pump for the Yaris unless it fails again, anyway. My thinking is that the way it failed wasn't critical so should the once new one fail in a similar way going forward there'd be no great rush to replace it. It seems that the actual fault with the pump was with it's integral speed sensor. A quick look at the partially drained reservoir bottle revealed that coolant was circulating prior to disassembly and a bench test comparison between the faulty one and the once new one concluded no noticeable (by ear / feel) difference in the actual speed of rotation. Further testing revealed full continuity from all relevant connecting cables to the relevant connections on the power supply ECU / fuse/relay box so the fault had to be either in the power supply ECU or (as seems to be the case) the sensor within the pump. Hence I've drawn a line under it as adequately repaired regardless of using a 2nd hand component.
Just for reference (as I know a lot of you drive hybrids) the symptoms in this case were an orange engine management light and an orange check EV system light being constantly shown on the dashboard together with the EV Mode and Eco Mode options being disabled and the cruise control system being disabled. I don't think the younger not so young lad noticed anything other than the lights but in addition to the disabled systems it was also evident that the car stopped using it's EV mode almost immediately after moving off so was (presumably) using more petrol than normal as well. The fault code given by my OBDeleven (now licensed by Toyota as well as VAG and BMW) was P314A - Inverter Coolant Pump Speed Signal.
« Last Edit: August 28, 2025, 04:57:00 pm by Rat Catcher »
Re: Hold strong Rc
« Reply #243 on: October 02, 2025, 01:55:52 am »
For a second….
Re: Hold strong Rc
« Reply #244 on: October 02, 2025, 04:04:30 pm »
For a second….
A Roozi Shah, A Roozi Shah,A Roozi Shah,Shah!! 8)
