Author Topic: Bye Bye Taxigame  (Read 7869 times)
Re: Bye Bye Taxigame
« Reply #30 on: April 03, 2020, 04:01:52 pm »
Sorry Meant is The one and only the oneandonly Royston ?
« Reply #31 on: April 03, 2020, 04:06:16 pm »
Funny enough I thought the same thing the other day I don't know why
« Reply #32 on: April 03, 2020, 04:10:03 pm »
Availability Bias / Availability Error: Simple Definition
Bias > Availability Bias / Availability Error
Definition
The term “availability bias” has two distinct meanings, depending on where you’re using it:
In assessement and decision making, it refers to readily available memories.
In meta-analysis, it is used as a synonym for publication bias.
1. Use in Assessement and Decision Making
Availability Bias (also called availability error) is figuring out odds from the first thing that pops into your head. A more recent memory, or one that you think is more important, has more bearing on your calculations than distant or hard-to-recall memories.
It’s called availability bias because of the distorted (biased) results. It’s also sometimes called the availability heuristic (which means a “rule of thumb”). Unlike sound calculations, availability bias accounts to nothing more than a quick guesstimate.
In Advertising
availability biasAdvertisers use the availability heuristic to their advantage. If they want a certain fact to pop into a viewer or readers head, they use repetition and visual language. Catchy slogans in commercials repeat over and over again. Negative facts are downplayed in vague or abstract ways. Think about drug ads: positive effects have simple language with large type and color, while side-effects are usually glossed over with small black and white type and fast language.
If you think of buying a lottery ticket, chances are the first thing that comes to mind are the lavish lifestyles of lottery winners. Or perhaps a phrase like “you gotta be in it to win it.” Maybe you just feel it’s your lucky day. That’s because lottery commercials focus on the one winner instead of the millions of losers. If commercials focused on the real odds (one in several million) and the scores of sad losers who just spent their last dime hoping to get rich, you wouldn’t buy a ticket.
2. Availability Bias in Meta Analysis
Simply put, if you base your analysis on readily available material, you’re analysis is likely to include availability bias. In this context, some authors call this type of bias source bias, information bias, or retrieval bias.
Light and Pillemar (1984) outline a simple way to find availability bias in publications. All things equal, small studies should have the same average effect size* as large studies. However, small studies will vary more due to sampling error. If you graph the sample size against effect size, the result should look like an upside down funnel. If it doesn’t, then suspect availability bias. However, there could be other reasons (see: Funnel plot for other possible causes).
availability bias
A funnel plot showing treatment effect vs. study size.
*Effect size indicates how much of an effect. For example, which works best: drug A or drug B?
Reference:
Tversky, A. and Kahneman, D. (1974). Judgement under uncertainty. Science, 185, 1124-1130.
https://www.statisticshowto.com/availability-bias/
« Reply #33 on: April 03, 2020, 08:21:09 pm »
And why did Supermarket workers not get it and Gardai and Firemen?.
+1. Should be available to all essential workers. The brits have expanded their weekly Thurs clap as recognition of all essential workers, not just those in the NHS. We should do the same if we haven't already.
« Reply #34 on: April 03, 2020, 08:36:25 pm »
I already had the clap!!
« Reply #35 on: April 04, 2020, 10:07:56 pm »
Just heard there will be a round of applause for courier and delivery drivers on Monday.
It will be sometime between 9am and 5pm.
« Reply #36 on: April 05, 2020, 09:18:06 am »
Laffin
« Reply #37 on: April 05, 2020, 06:30:25 pm »
Just got chicken balls and chips from the local Chinese takeaway, it  was the dogs Bollocks!
« Reply #38 on: April 05, 2020, 06:34:33 pm »
Sorry I thought you said it was the chickens bolkox
« Reply #39 on: April 05, 2020, 06:43:16 pm »
There’s the email with the survey. I answered and said No
« Reply #40 on: April 05, 2020, 06:44:58 pm »
The Generals never stormed a machine gun nest.
« Reply #41 on: April 05, 2020, 06:54:43 pm »
"Many taxi drivers have contacted us to see how they could help"........did you ever hear such bolloxology..
« Reply #42 on: April 05, 2020, 08:36:38 pm »
"We've been thinking of different ways that WE can help" more bollxlgy
