Author Topic: battry going flat  (Read 7985 times)
Re: battry going flat
« Reply #1 on: April 22, 2020, 03:07:01 pm »
Surely it's only a matter of going out once or twice a week and starting the car for a few minutes ?
« Reply #2 on: April 22, 2020, 03:09:06 pm »
Clog up the DPF if you do it too often you need to give it a run get oil up to temp .
« Reply #3 on: April 22, 2020, 06:51:26 pm »
Brought mine for an spin today,give the brakes some working time.....felt the gearshifter and had a snakey wank....like ye do!!
« Reply #4 on: April 28, 2020, 04:12:10 pm »
Big Dommos sisters Fellas first wifes youngfella right scumbag not one of us not from the flats but is a reformed character now .He knew a lot about cars first driving ban when he was 11 anyway Im just trying to show he has form when it comes to motoring so his advice might be good .He recons you should drive your motor for at least half an hour a week get it up to temp and let the oil run around the engine do not just turn it on and sit in the garden drive it .He recons if you dont drive it and get the juices circulating you will perished hoses and possible get  airlocks and leaks .
« Reply #5 on: April 28, 2020, 06:17:37 pm »
Had to buy a new battery...Too many jump starts...It had more dead cells than the Provos...
« Reply #6 on: April 28, 2020, 08:33:19 pm »
The battery in the PRIUS is fine,
Guilty as charged! 8)
« Reply #7 on: April 29, 2020, 11:35:07 pm »
Lidi battery charger 17 euro
Well worth it
« Reply #8 on: April 30, 2020, 09:56:54 am »
I have a battery charger but it would take ages to charge a modern diesel battery. Jump leads present a pretty much instant solution.
Offline Golfer14
« Reply #9 on: April 30, 2020, 01:08:11 pm »
Had to replace my battrey new years eve .Mechanic had a new one that he got for a customer ,but stuck it into my yoke to get me out on the road .€90 fitted .Had bought a few battreys off a crowd on cappagh rd over the years (cost price ) Tim Molloys .
Offline Golfer14
« Reply #10 on: April 30, 2020, 01:12:12 pm »
 Just to add my yoke 2015 modie 2.0 litre ,180 bhp ,has stop/start ,mechanic said normal heavy duty battrey is fine .!!
Offline Lizzzy
« Reply #11 on: April 30, 2020, 01:18:49 pm »
Your mechanic is wrong, that battery won't last pissing time.
Offline Golfer14
« Reply #12 on: April 30, 2020, 01:35:21 pm »
I dont use the stop/start tho .Battreys life span can varey ,but i usually get about 3 years out off them .Time will tell .
« Reply #13 on: April 30, 2020, 01:36:47 pm »
Pissing time might be all I can afford when all this is over!
« Reply #14 on: April 30, 2020, 01:57:06 pm »
Iif I ever buy a new car, the first thing I'll make sure of is that it doesn't have one of those what they call a feature, where the car stops every time you stop at a traffic light or anywhere else. I just cannot see how that is labeled as being a feature
