Author Topic: Sneeze Guard Mk1  (Read 22027 times)
Re: Sneeze Guard Mk1
« Reply #30 on: May 12, 2020, 03:01:42 pm »
Its bespoke cut to size I will compress fit it using the seats to lock it in between the back of the seat and the roof .I have double sided adhesive foam to fit to pillars  with hidden cable ties .I tried to post a picture but is says file to large .
« Reply #31 on: May 12, 2020, 04:07:33 pm »
A little bit messy
Held on with clamps to headrest
Fairly well sealed all round:
hung off coat hangers, keeping it tight
Held firm to seat at rear pockets giving full leg room
Fuck it'll do grand
@ Roy, I can't see or understand the fittings with coat hangers to the head rest.
Could you please explain or post another photo ?
« Reply #32 on: May 12, 2020, 04:16:37 pm »
Be careful putting any type of adhesive on the car John M because when you go to take it off it will leave a residue which will quickly turn in to a black stain which is near impossible to shift even with WD40.
« Reply #33 on: May 12, 2020, 04:22:00 pm »
Dont see a screen as a full time fitting so its bound with pipe insulation to prevent any cutting of roof lining or seats from any movement would of preferred to use proper edging but cant get any .
« Reply #34 on: May 12, 2020, 05:02:06 pm »
« Reply #35 on: May 12, 2020, 05:02:59 pm »
  Pattern Renault Fluence .
« Reply #36 on: May 12, 2020, 05:03:37 pm »
« Reply #37 on: May 12, 2020, 05:05:21 pm »
and that gentlemen is how you make a sneeze guard for a score .
« Reply #38 on: May 12, 2020, 05:08:30 pm »
What about, theoretically, the most dangerous passenger in the front seat? Will you refuse front seat passengers for the next 2 years, or fit an add on to the rear screen, to protect you from the front seat passenger?
« Reply #39 on: May 12, 2020, 05:09:54 pm »
Operation snots funny ..Rang somebody who said DO NOT USE PERSPECTS it will shatter use Polycarbonate .So using me old ability to forage on site I managed to get an off cut big enough to do the job for choice then I made a pattern (Renault Fluence ) Threw the lad in the factory a score for smokes .Bespoke screen supplied and fitted for a score .
pictures?
« Reply #40 on: May 12, 2020, 05:14:33 pm »
I would imagine that you are similar to myself John M, A bit of a character and a joker in the cab who enjoys the banter with customers, but with a full screen up all that is gone.
The fares like the one posted below will be a distant past.
I had this fare in the cab one night, a mature bearded man of about 45, it was about 3am in the morning and he asked to go to Blackrock (Southside), along the way he spewed all the usual drunken bullshite telling me how much he loved and adored his 7 year old daughter, then he changed his mind and asked to be brought to Knocknaheeny (Northside). As we approached his destination he started to tell me of how his ex-partner (from Knocknaheeny) denied him access to his daughter and how he was now going to give her a piece of his mind and see his daughter.
I pulled in the cab on Bakers road before making the turn fer Knocknaheeny and turned on the man stating; "Look, I'm not holding you prisoner and I'm not telling you what to do, I will bring you wherever you wish to go, but I will break down the situation fer you. If you go banging on your ex-partners door at 3 in de morning 'Full of drink' then she will come out screaming or call the Guards or maybe both, your 7 year old daughter will be awoken and she will be terrified if there is a Garda presence in the middle of the night and most likely your ex-partner will use the situation to turn the child against you. In the next Ten minutes you may lose all access to your child forever. Now think about what I've said and tell me where you want to go ?"
He thought about it fer about Ten seconds and then said; "Home to Blackrock please Mr Taximan".
There was no further chat in the cab as his drunken confidence had been shattered, the fare at Blackrock was 27Euro, but I only asked fer a Score because of all the diversions, he handed me 30Euro on departing saying; "Keep it, Your a Good Man".
« Reply #41 on: May 12, 2020, 05:22:02 pm »
Nice work John M, I'm impressed but ya could have cleaned out the back before taking the photos !
« Reply #42 on: May 12, 2020, 05:23:34 pm »
When Im ready to take a front seat passenger ill remove the screen .
« Reply #43 on: May 12, 2020, 05:35:12 pm »
I have very temporary screen guards up, and I manually lock the front passenger door and direct passengers to the rear seats.
However if there are 4 passengers then (as fares are in short supply) I will allow a Front seat passenger.
« Reply #44 on: May 12, 2020, 05:45:11 pm »
