Author Topic: Sneeze Guard Mk1  (Read 22008 times)
Sneeze Guard Mk1
« on: May 09, 2020, 10:59:47 pm »
Re: Sneeze Guard Mk1
« Reply #1 on: May 10, 2020, 01:35:47 am »
The orders should be flying in next week....
« Reply #2 on: May 10, 2020, 10:02:38 am »
Perspex shouldn’t be used. It breaks to easy and will cause you issues. Polycarbonate is the only thing to use.
« Reply #3 on: May 10, 2020, 10:14:07 am »
This crowd just outside of Ballincollig in Cork called Blarney Trading do plastic sheeting
I measured my cab and it is about 1.5 meters from window to window and approx a bit less from roof to floor.
Blarney Trading sell sheets of hard plastic which measure 1.8 meters by 1.2 meters and are 2.5mm thick (which is a Tenth of an Inch or a quarter of a centimeter) and cost 55 Notes.
Yer-man-o on the phone told me that it would be perfect fer a Taxi screen and that I could drill holes into it to fit cable ties to hold it on to the headrests but warned me Not to use a Jigsaw to cut it as it could be brittle and crack if heavy machinery was used on it, he said a simple handsaw would cut it easily.
« Reply #4 on: May 10, 2020, 10:17:23 am »
Yer-man-o would tell you anything to get your €55 off ya.
Fools and their money
« Reply #5 on: May 10, 2020, 10:25:02 am »
If'n your interested Roy, then surely a Dooblin supplier would have the same product.
I would suggest a line of metal tubing in the drill holes to protect the plastic sheet from the cable ties that secure it to the head rest.
A line of metal tubing can easily be obtained from cutting a small piece from a Coca cola can and secured by a tiny piece of duct tape.
And a bit of sand paper to smooth off the cut plastic edges.
« Reply #6 on: May 10, 2020, 10:32:57 am »
So what you up to fer making a Crust these days Vik, Working or on the Pox 350 Dole ?
« Reply #7 on: May 10, 2020, 11:06:05 am »
Looked on the 353plastic.ie site where I bought mine ... sold out
« Reply #8 on: May 10, 2020, 11:07:43 am »
I might buy another sheet when hardware stores resume. i'd buy a 5mm thick one next time, experience will help make the cutting better
« Reply #10 on: May 10, 2020, 01:17:17 pm »
Theres nothing enough room in the Prius....if I'm to have me seat back enough ....think I'll be buying a bag o masks and a pair ray bans
« Reply #11 on: May 10, 2020, 01:29:49 pm »
2mm perspex is flexible enough to mould to the back of the seat, so legroom does not need to be compromised
« Reply #12 on: May 10, 2020, 04:42:52 pm »
I have a contact in Engineers Ireland, anyone want to run their ideas by them?
« Reply #13 on: May 10, 2020, 05:27:16 pm »
Im sure your engineer friend will tell you that certification of any screen would cost tens of thousands of Euro in tests and conformance certs .I posted what Paddy from Axa replied to me .I have no idea who Paddy is no second name and E mail not on headed notepaper just a reply attached to my original question .
