Author Topic: accept follow up job  (Read 10360 times)
« on: May 26, 2020, 03:06:31 am »
The old app got an update there in the past few days and when you're nearing the passenger's destination the Accept Follow up job activates automatically and jobs come flooding in and taking over your screen so you can't see where you're going with your current passanger. You can't fucking disable it either. It used to be an option that you could go in to the settings and tick on and off if you wanted the accept follow up job offers.
On the old app the big issue was that it would zoom in to space when you were approaching the drop off but this is even worse. You're dropping in Raheny and the screen will pan over to Artane or Clontarf or Coolock or whereever letting you know about another fare, interfering with getting your current passanger to their destination smoothly. You ex that one and another comes in. You ex that one and another comes in etc etc. Your screen is bouncing all over the fucking kip.
I've also noticed that sometimes when you're busy exing all the follow up jobs that hijack your screen the app freezes you out when you go free again. It's like you're being punished for not accepting the follow up jobs. I was frozen out for an hour last Saturday night and half an hour on Sunday night. You can't negotiate the final stages of a passanger's drop off point undisturbed because your screen gets flooded with bollocks. Again you can't disable the follow up job offers anymore.
I mean who the fuck field tested this? Was there a driver survey I did'nt get to vote to replace the zooming in to outer space with an even worse flaw. For fffffffffffffffffffffffffffuck's sake. I don't wanna hear any dirt from scalymount about how it's all my fault or some bollocks either.
Re: accept follow up job
« Reply #1 on: May 26, 2020, 07:04:17 am »
Simple solution is to turn the app off and wait for 10 minutes, after that wait another hour, then hit the delete app and your problem is solved and no more paying 15% to fleecenow.
I hope this helps.
Love and kisses
Tony.
Offline Golfer14
« Reply #2 on: May 26, 2020, 07:13:08 am »
« Reply #3 on: May 26, 2020, 08:08:26 am »
Down here in Cork I'm not getting all the glitches that you are getting DMG, but still new glitches are now in place like the screen freezes when you are 100 meters from your pick up point, where before it mostly brought you to their door.
« Reply #4 on: May 26, 2020, 09:29:56 am »
Sorry for yer loss lads!!
« Reply #5 on: May 26, 2020, 11:53:08 am »
That's strange I've never had that freezing when you're approaching the destination problem. I've identified two other problems with the new update. When you press arrived the map oftens starts scrolling southwards at a fast rate for no reason. Also when it tells you a customer has cancelled a fare there is a blue button that says next. you press it and nothing happens. you have to sign in and sign out to go free again. can you still see the option to turn on/turn off the accept follow up jobs in your settings?
« Reply #6 on: May 26, 2020, 11:56:44 am »
Hopefully the FN IT people will have them problems resolved by the time I'm back in action
« Reply #7 on: May 26, 2020, 03:49:06 pm »
Working?
It's all a loada Bollocks! 8)
« Reply #8 on: May 26, 2020, 09:10:24 pm »
laffin.
« Reply #9 on: May 26, 2020, 09:23:43 pm »
Problems arise when you leave these IT guys with nothing to do except "update"
« Reply #10 on: May 27, 2020, 06:45:22 am »
........That's strange I've never had that freezing when you're approaching the destination problem. I've identified two other problems with the new update. When you press arrived the map oftens starts scrolling southwards at a fast rate for no reason. Also when it tells you a customer has cancelled a fare there is a blue button that says next. you press it and nothing happens. you have to sign in and sign out to go free again. can you still see the option to turn on/turn off the accept follow up jobs in your settings?
Yes, I turned Off the 'Automatic Follow on' feature the First day it was introduced and have never changed it back, but I do manually accept Follow on jobs if they are within reason.
As fer the Freezing thing, then maybe Freezing was a bit of an exaggeration, to explain it better, when I get to within 50 meters of my customers destination the Blue line disappears and you have to hit 'Arrived' and manually zoom in to get to the exact location.
« Reply #11 on: May 27, 2020, 08:30:34 am »
Do yis not know where yisser going?
How in the name of fuck did ye manage to navigate yisser way around before hailo or Google maps is beyond me.
« Reply #12 on: May 27, 2020, 08:53:48 am »
Back in the day you got an address and when you got there had to use a torch to see the house numbers.
I'm only 11 years at this game but I remember starting off (No Sat Nav, No Google maps) and we had to use actual maps to find our destination.
A former base manager gave me an old Garnim Sat Nav about 2 years in to the job, it changed my life !
« Reply #13 on: May 27, 2020, 09:47:47 am »
Here's a tip DMG turn off your automatic updates on your driver app.Wait a week or two before updating.They're always updating it but rarely ever improve it.The app was perfect years ago.
Yer probably just too busy though.
« Reply #14 on: May 27, 2020, 07:57:27 pm »
Use an ordnance survey map.
No Google map mistakes.
