Author Topic: Swastika  (Read 7632 times)
Swastika
« on: November 19, 2021, 12:27:22 pm »
Germany and Austria are to introduce restrictions on Unvaxinated people .(When was the last time those two countries decided to pick on a certain group of people ) did it solve the so called problem? oops oops oops
Re: Swastika
« Reply #1 on: November 19, 2021, 02:26:31 pm »
You can't let the gobshites win. Allowing them to refuse vaccines while they hoover danced on coke up their noses. You couldn't write this shit.
COVID Vaccine Ingredients
There are two COVID-19 messenger-ribonucleic acid (mRNA) vaccines currently authorized for emergent use in the United States: the Pfizer-BioNTech and the Moderna vaccines. A third vaccine developed by Johnson &Johnson (J&J) Janssen uses a viral vector platform. Conventional vaccines, rely on weakened and inactivated pathogens or a fragment of the pathogen to trigger an immune response. In contrast, the COVID-19 mRNA vaccines use a new approach by which mRNA is delivered into our cells to provide the genetic instructions for our own cells to “temporarily” make a “specific” viral protein (the coronavirus spike protein) that triggers an immune response. The J&J COVID-19 vaccine is a type of “replication-incompetent vector vaccine.” This vaccine also contains the genetic instructions to express a stabilized coronavirus spike protein, but instead of mRNA, these instructions are delivered via DNA stored inside a modified vector virus (Adenovirus 26). This adenovirus has been engineered to enter the human cells and deliver the desired genetic information without replicating itself or causing illness. Once inside the cells, the DNA encoding for the coronavirus spike protein can be read by the cell and transcribed into mRNA. At this point, the J&J vaccine acts similarly to the mRNA vaccines.
The Pfizer-BioNTech COVID-19 vaccine is made of the following ingredients:
mRNA – Also known as messenger ribonucleic acid, mRNA is the only active ingredient in the vaccine. The mRNA molecules contain the genetic material that provide instructions for our body on how to make a viral protein that triggers an immune response within our bodies. The immune response is what causes our bodies to make the antibodies needed to protect us from getting infected if exposed to the coronavirus.
There are rumors that mRNA vaccines will alter our DNA because the RNA molecule can convert information stored in DNA into proteins. That’s simply, not true. It’s critical to note that the mRNA vaccines never enter the nucleus of the cell, where our DNA is stored. After injection, the mRNA from the vaccine is released into the cytoplasm of the cells. Once the viral protein is made and on the surface of the cell, mRNA is broken down and the body permanently gets rid of it, therefore making it impossible to change our DNA.
Lipids – The following lipids are in the new COVID vaccine. Their main role is to protect the mRNA and provide somewhat of a “greasy” exterior that helps the mRNA slide inside the cells.
((4-hydroxybutyl)azanediyl)bis(hexane-6,1-diyl)bis
(2-hexyldecanoate), 2 [(polyethylene glycol)-2000]-N,N-ditetradecylacetamide
1,2-Distearoyl-snglycero-3- phosphocholine
cholesterol
Salts – The following salts are included in the Pfizer vaccine and help balance the acidity in your body.
potassium chloride
monobasic potassium phosphate
sodium chloride
dibasic sodium phosphate dihydrate
Sugar – Basic table sugar, also known as sucrose, can also be found in the new COVID vaccine. This ingredient helps the molecules maintain their shape during freezing.
The Moderna COVID-19 Vaccine is made of the following ingredients:
mRNA – Like the Pfizer BioNTech vaccine, Moderna’s also uses mRNA technology to build antibodies against COVID-19.
Lipids – The Moderna vaccine also requires lipids to help deliver the mRNA to the cells.
SM-102
1,2-dimyristoyl-rac-glycero3-methoxypolyethylene glycol-2000 [PEG2000-DMG]
cholesterol
1,2-distearoyl-snglycero-3-phosphocholine [DSPC]
The remaining ingredients (below), including acids, acid stabilizers, salt and sugar all work together to maintain the stability of the vaccine after it’s produced.
Acids
Acetic acid
Acid Stabilizers
Tromethamine & Tromethamine hydrochloride
Salts
Sodium acetate
Sugar
Sucrose
The Johnson & Johnson Janssen COVID-19 Vaccine is made of the following ingredients:
Recombinant, replication-incompetent adenovirus type 26 expressing the SARS-CoV-2 spike protein:a modified and harmless version of a different virus (Adenovirus 26) is used as a “vector” to deliverthe DNA gene sequence to produce the coronavirus spike protein. Once the modified adenovirus vaccine enters into the cells, the body of the virus essentially disintegrates and the DNA material within it travels into the nucleus of the human cell where it is transcribed into mRNA. The coronavirus spike protein is then produced and displayed on the cell’s surface, prompting the immune system to begin producing antibodies and activating T-cells to fight off what it thinks is an infection.
The Adenovirus 26 in the J&J vaccine does not replicate, and like the mRNA vaccines, does not change our genetic code.
Acids
citric acid monohydrate
Salts
trisodium citrate dihydrate
Sugars
2-hydroxypropyl-β-cyclodextrin (HBCD)
polysorbate-80, sodium chloride
Other ingredients
ethanol
That’s it!
“Overall, the main ingredients in the Pfizer-BioNTech and Moderna vaccines are very similar, and all three vaccines were found to be safe and efficacious in preventing symptomatic COVID-19 disease in rigorously conducted clinical trials. These COVID-19 vaccines are safe and went through the same rigorous testing process as other vaccines before being approved for emergent use in the United States. Although local and systemic side effects have been reported, as is the case for many other medical interventions, the risk of lacking protection against COVID-19 and developing severe disease far exceeds those posed by the vaccine itself. ” says Juan Ravell, M.D., division chief of allergy and immunology at Hackensack University Medical Center. “These ingredients are safe and the development of these COVID-19 vaccines marks a huge step towards acquiring herd immunity and the end of this pandemic.”
Re: Swastika
« Reply #2 on: November 19, 2021, 02:30:44 pm »
TOP QUALIFICATIONS THERE .... says Juan Ravell, M.D., division chief of allergy and immunology at Hackensack University Medical Center. Im sure the girl on the make up counter in Booths would tell you something similar .
Re: Swastika
« Reply #3 on: November 19, 2021, 02:32:10 pm »
What booths would that be?
Re: Swastika
« Reply #4 on: November 19, 2021, 06:19:08 pm »
Ye always have to stick the booth in SB!!
Re: Swastika
« Reply #5 on: November 19, 2021, 06:45:06 pm »
Aah, oul Ermy, wouldn't say booth to a goose!
Slagging a man's job title when his is  cabbie!
Sheesh! 8)
Re: Swastika
« Reply #6 on: November 20, 2021, 09:15:08 am »
cholesterol
potassium chloride
sodium chloride
SM-102
cholesterol
Acids
Acetic acid
Acid Stabilizers
Salts
Sodium acetate
Sugar
Sucrose
Acids
Salts
Sugars
Other ingredients
ethanol
That’s it!
Quote bullits
Yur joking bullits I hope ....
Re: Swastika
« Reply #7 on: November 20, 2021, 11:47:29 am »
Once leppers rang bells and chanted UNCLEAN .then Jews were forced to wear stars Slaves were branded .How will they mark the unvaxinated .Its all bollox just like the 4 month old Maggie Simson has learned to hate the other baby with the one Eyebrow it seems that now that Europe is all friendly and not at war with each other we need someone to be a figure of hate its now the Unvaxinated we done Jews ,Pooffs,Blacks ,imigrants all that we are left with is learning to hate ourselves .Dangerous nonsense locking down people who dont want a medical procedure .
Re: Swastika
« Reply #8 on: November 20, 2021, 11:50:17 am »
SHOT AND WOUNDED Dutch police have shot and wounded at least two people after rioting erupted in Rotterdam over new Covid-19 measures.
"Police were forced to draw their weapons and even fire DIRECT  shots," Mayor  told a press conference this morning.
« Last Edit: November 20, 2021, 11:54:00 am by John m »
Offline Justin Time
Re: Swastika
« Reply #9 on: November 20, 2021, 02:55:20 pm »
Everyone should be vaccinated, wear a mask and social distance.
If you don't you're a dick and it will only prolong matters.
Hold the fuckers down if you have to.
Re: Swastika
« Reply #10 on: November 20, 2021, 05:01:23 pm »
Well, they were warned that being unvaccinated was potentially dangerous  ;)
Online Bob Shillin
Re: Swastika
« Reply #11 on: November 20, 2021, 05:13:50 pm »
Mmm, yes, and compulsory sterilisation because the world is over populated, "hold the fuckers down if you have to". Kill all those who spread diseases which are currently incurable.
Re: Swastika
« Reply #12 on: November 20, 2021, 06:03:10 pm »
It's mad the lengths people will go to not to get vaccinated.Getting into a riot over a little needle.For an easy life I'd just take the needle.I picked up a young lad a few weeks ago selling dodgy vaccination cards.Why would ya be bothered for fuks sake.
It is interesting how many people have said on here and in the car it's like Nazi Germany.None of yous jew faces would last five minutes in Nazi Germany.
Re: Swastika
« Reply #13 on: November 20, 2021, 08:00:44 pm »
It's all a loada bollocks.
Re: Swastika
« Reply #14 on: November 20, 2021, 08:59:23 pm »
Very very fuking dangerous precident.....
Compulsory vaccination .....
Riots ? Bring them on ....
