Author Topic: DPF problems.  (Read 7212 times)
Re: DPF problems.
« Reply #15 on: November 01, 2022, 01:45:54 pm »
relax the cacks. school's in session.
you're lucky you have the new avensis that tells ye "DPF full" on the instrument panel. my aulwan has the same avensis as yours and she does tell me "the car is sayin DIV full again what does that mean". the new avensis does'nt even go inta limp mode like the T27 model that i had. you were notified by a full dpf by virtue of a myriad of 6 or 7 warnin lights. i remember the first time it happenned and the car lost all power. i was brickin it. obviously i did'nt know what was happennin or what a DPF was.
Diesel is a dirty burnin fuel. A DPF absorbs all the soot and carbon like a sponge that otherwise would get belched out the exhaust in plooms of black smoke like the old school diesel lorrys. Problem is the DPF gets full. The way to empty it is to blast a lot of heat through it. Dipetane is great stuff. It works my raising the octane number of the fuel which means you get a more efficient burn of the fuel. more efficient burn means more power, more heat created, less oppurtunity for soot to build up in it.
how i remedy my aulwan's DPF full or any DPF full car;
1. Wait till the tank is nearly empty
2. Grab the fuckin car keys off her and go to the petrol station
3. Throw a full bottle of Dipetane in
4. Fill tank to about a quarter full on top of the Dipetane to make sure it mixes well and you get a strong concoction of souped up Dipetane/fuel
5. Floor it up and down the motorway in a loop holding the revs at 2500rpm to create maximum heat for the soot in the DPF to turn to ash and empty out.
6. Process can take anywhere from 30 mins to an hour dependin how full the DPF is.
7. DPF full message will automatically dissappear
8. It's advisable to do an oil change afterwards because holding the engine at 2500rpm for such an extended time will riddle the oil.
9. To keep the DPF in good order add a little bit of Dipetane at every fill up and every once in a while on the motorway gun the car at 2500rpm for 10 minutes or so.
Mechanics simulate this by doing a "forced regeneration" of the DPF. They'll connect a computer and rev the car at 2500rpm in the garage for 30 mins but the engine ideally hasta be working very hard (up a hill with 4 yanks on board) to speed the process along. If that does'nt work they'll connect a hose to the DPF and wash out the soot and build up carbon. If you get a pain in your nuts with the DPF keep gettin full you can have it removed. pricey though because they're usually buried behind the engine. once they're gone you'll get a strong fume smell out the exhaust which can be remedied by using Dipetane at every fill up.
Re: DPF problems.
« Reply #16 on: November 01, 2022, 03:11:02 pm »
There are too many holes in your story Belker.Someoe isn't doing maintenance somewhere.I'd be afraid to leave ya in charge of a shopping trolley.Thankfully the Freenow bonus system will cover all the damage to yer vehicle that happened while you were chasing imaginary medals. I'm done here.
GOOD !
You weren't much help.
Yea but he's rite Ken.....
Yu probly never dip yur oil or sumtin ...its only a new car isny ?
Yur engine is probly bollixed  aswell drivin round wit 3 liters oil .....them turbo tingys start goin wit droppin oil pressure
Buy a prius ....diesel is dead fuk sake wat wer ya tinkin buyin a new antique  ::) ???
Re: DPF problems.
« Reply #17 on: November 01, 2022, 05:10:18 pm »
Was just gonna post that years ago with my old diesel Octavia (2007 so no dpf), I got a secondhand turbo instead of a secondhand engine.  Can't remember the cost but i think it was around the €700 mark.  Might even have come with a 6 month warranty.  But my mechanic was a bit skeptical and he was just humouring me with the turbo replacement and basically was of the opinion that the car was fukked anyways.   Kept going for another few years so it all worked out.
Re: DPF problems.
« Reply #18 on: November 01, 2022, 05:54:20 pm »
Kenneth how many 10 hour shifts non stop do you do .your engine oli is burned .Doing city driving non stop like we do 10,000 Km between oil changes would save a lot of problems .Huge difference between a Sales rep on a motorway and urban driving .Especially in a Manuel .You often see a plume of black from some dodgey diesels when the driver changes gear .
Re: DPF problems.
« Reply #19 on: November 01, 2022, 07:43:50 pm »
Kenneth .ask around or go to your local Motor ELECTRICIAN not Garage .Get him to run a diagnosis on it ,You are reporting three diagnosis .Fucked Turbo ,Fucked DPS and Knackered engine .Fixing one of them might fix it for a few weeks Mechanic wont give a fuck .Before you part with coin go get a different Professional opinion .
I throw a bottle of this in twice a year ..https://www.google.com/search?q=liqui+moly+diesel+purge&rlz=1C1CHBF_enIE1026IE1026&oq=liqui+moli+diesel&aqs=chrome.1.69i57j0i10i512l9.17050j0j15&sourceid=chrome&ie=UTF-8
« Last Edit: November 01, 2022, 07:52:20 pm by John m »
Re: DPF problems.
« Reply #20 on: November 02, 2022, 06:42:50 am »
Kenneth if it is a problem turbo that is causing the problem fixing that wont fix the blocked DPF just prevent it in the future .The Auto Electricians seem to have better Diagnosis tools show up all the faults .Also by going to an Auto Electrician he wont spoof ya as he isint looking for mechanical work .Cost you about 50 for a full diagnosis and printout 20 for a quick Yer Fucked there Boy job diagnosis .Money well spent before the spanner Monkies get loose at it .
Re: DPF problems.
« Reply #21 on: November 02, 2022, 10:25:55 am »
Infrequent oil change or cheap shitty oil I rekon  oops
Re: DPF problems.
« Reply #22 on: November 02, 2022, 10:36:33 am »
I couldn't get me head around the numbers for these repairs.2500 for fuks sake for a turbo.My car was only 6000.
Then the DPF will likely need more work.Another 600.
Then the engine was running half full of oil.He might have gotten lucky if it was a Toyota engine but I believe it's a BMW unit.Hope he gets out on the cheap side.
« Last Edit: November 02, 2022, 10:39:56 am by mercenary for hire »
Re: DPF problems.
« Reply #23 on: November 02, 2022, 12:12:06 pm »
Is it not illegal to remove it ?  oops
Re: DPF problems.
« Reply #25 on: November 02, 2022, 01:14:44 pm »
Booked in fer a new turbo on Mon week, 1400 Euro.
Re: DPF problems.
« Reply #26 on: November 02, 2022, 01:18:43 pm »
https://www.rte.ie/news/dublin/2022/1102/1332728-dublin-city-parking/
Occi I am just back from the Bookies .My bet A General election this year in Ireland @66/1 .Last night Marc Mc Sharry quit FF .Now the Maths we have a Minority government .If Mc Sharry and the Two X Greens vote against Leo for Taoiseach then its Game over the Country has no Taoiseach .You are aware that the date of the handover has been moved ?The Sums if the Three Bandits vote Against then the Technical Group do not have enough votes to elect Leo .I am hearing that Costello and Hourigan want the Mercisore deal vote suspended while Leo is Taoiseach if not they wont support him .
The Sooner the Greens and their Car hating nonsence is ousted the better for the Country and Environment .Its fuckology like this parking proposal that makes you realize they are Zealots .The Bike loving City Manager got a 20k wage increase last week while workers in Liffey Valley were charged to park to go to work .
Re: DPF problems.
« Reply #27 on: November 02, 2022, 01:19:48 pm »
What about the DPF how will a new Turbo fix that ?
Re: DPF problems.
« Reply #28 on: November 02, 2022, 01:30:15 pm »
Not too sure, but that is what the fella in JD motors recommended and my own regular mechanic agreed with him.
Re: DPF problems.
« Reply #29 on: November 02, 2022, 01:39:22 pm »
Seriously Ken go to your local Auto Electrician they have top of the range Diagnostic software .You said your DPF was faulty .It could be caused by the Turbo but if you fix the Turbo how will that fix the DPF .Get a full printout of the Faults .I got caught with Satins Wheelbarrow for coin that didnt need to be spent Mechanics fixint stuff then scratching their heads when you bring it back a few ton lighter telling me I thought that was the Problem .Did the Garage show you a Printout of the Actual Turbo fault or was it tyre kicking guess work .50 Quid to your Local Auto Electrician for a Full printout of Faults is money well spent .Turbo problems usually have a Cause they are a Symptom of something else .For 50 I would get a second opinion .
