Author Topic: DPF problems.  (Read 7199 times)
Re: DPF problems.
« Reply #30 on: November 02, 2022, 03:08:53 pm »
Booked in fer a new turbo on Mon week, 1400 Euro.
What about the DPF how will a new Turbo fix that ?
Not too sure, but that is what the fella in JD motors recommended and my own regular mechanic agreed with him.
Ken .....I know fuk all bout cars ...an I don't want to  know either but anytime I changed a turbo the engine was bollixed an blew up soon after ....you don't have the millage up on yur car yet for yuer turbo to go prematurely especiallyon a toyota ...its usually a sign of bad engine oil pressure..that was caused by by yur oil either low or wrong oil or  not changed  .....yur turbo is is flying around at gazillion Miles a minute an it's furthest from yur oil pump an shiitty oil  or low oil pressure or wrong oil will destroy it .....wen it starts to wear the oil gets  blown or sucked inta yur combustion chambers tingys an burns  an that'll fuk up yur dpf filter ide imagine cause oil soot particles tingys  are bigger than diesel sooty particles tings  an they stinky cnuts ... ide say yuv bean drivin that ting round wit smoke comin out of its arse for ages ...
Wer ya penny pinchin on ur servicin intervals  ::fight
Own up
Merc is rite ...get a prius ...
Re: DPF problems.
« Reply #31 on: November 02, 2022, 03:19:28 pm »
Quote from: Rat Catcher on October 15, 2022, 11:56:12 am
Ya can't go wrong with a diesel.
Quote from Belker:
Takes a Licking ! Keeps on Kicking !!
If you want a discount on the turbo I'll call my cousin in Toyota. Long Mile Road. I think Hal got 20% off a battery.
Re: DPF problems.
« Reply #32 on: November 02, 2022, 06:16:42 pm »
This great stuff
Re: DPF problems.
« Reply #33 on: November 02, 2022, 06:57:15 pm »
When a diesel car I had a few years back failed on emissions ,a litre of Dipitane and  then Portlaoise and back  on the Nass dualer in 3rd gear did the trick
 ::fuck ::fuck.
Re: DPF problems.
« Reply #34 on: November 04, 2022, 05:42:05 am »
No noticeable smoke coming out of the exhaust.
Car is alwaus serviced about 100km befrore it's due and enigine oil level is checkd frequently.
I always get my oil at the same garage because they have a chart to show which is the correct oil fer the car.
John M's idea seems the best and I would have done that if I had seen it in time.
But it's booked in now fer a new turbo and a Monkee deposit paid on it so I will stick with that plan.
Re: DPF problems.
« Reply #35 on: November 04, 2022, 08:32:07 am »
Sounds like a heap if shite Belker, have you considered going hybrid?.Your chances of the DPF being bollixed are very high even with a new turbo.That three liters of oil had to get out somewhere.
Start shipping for a new car if I was you.
Re: DPF problems.
« Reply #36 on: November 04, 2022, 09:10:42 am »
 .... someone was doin a scrooge Ken....an ya have form ..cmon ..........yur bleedin obsessed wit savin a half a cent off a liter o dirsel ....someone was penny pinchin to fuk that car up an it was oil related .....Toyota don't just fall apart ....
Confess Ken........ya baut oil in tescos at 2 bottles for a tenner an told yur mechanic that'll do ...or fuked it in yurself ....its time yu had a good look in the mirror an faced the consequences of yur obsessive pathological frugality ...its borderin on ethnic  Jew  ken ..
Merc is spot on again here have say he sppotted it straight away ......if I was assessing yur car in a guarantee claim .....ide hang yur  bollix out of the nearest lamp post ...
Cmon ...out wit it ...wat  did you did  ?
Re: DPF problems.
« Reply #37 on: November 04, 2022, 09:33:42 am »
 Strange the oil light never came on.
Re: DPF problems.
« Reply #38 on: November 04, 2022, 09:56:55 am »
Doesn't have to jack .......the wrong oil ......its like if ya got a blood transfusion off a junkie riddled wit aids .... ....you be alrite for a bit goin about your business........then you'd wake up one mornin wit a terrible dose of  fartin an diarea ....Next minute yur lying horizontal at 10.00 o clock mass
 oops
Re: DPF problems.
« Reply #39 on: November 04, 2022, 10:19:54 am »
I'm not sure I'd agree with the erm's advice. We both owned MKII diesel Octys. Mine is still as good as new whereas the erm got rid of his having spent years referring to it as Satan's Wheelbarrow. Mine has never had anything other than diesel in the fuel tank and has it's oil changed every 20,000 kilos which is a little ahead of manufacturer specifications (on variable service it'd go somewhere between 25,472 kilos and 30,000 kilos before asking for an oil change). The important thing is to follow manufacturer specifications for both time/distance between oil changes and oil specification. 92% of engine wear / oil deterioration occurs when the engine is cold. I doubt your engine ever cools down, Ken!
I would agree with checking the oil level periodically. I check mine on the first weekend of every month. The MKII (with over 360,000 kilos and only 1 clutch change) is good as gold and never consumes oil. The MKIII, on the other hand, tends to need half a litre or thereabouts every second or third month. I believe the oil consumption is normal for that particular engine, being caused by periodic automatic DPF regenerations. Anyway, don't rely on the light to tell you if/when a top up is required. They tend to go well below the min level before the light comes into play so get into the habit of checking it regularly (whether through diagnostics interrogation, through the infotainment system or with the dipstick)... along with topping up screen wash and having a quick glance at brake fluid and coolant levels and check the condition of your tyres. In fact most of that is covered in Lesson 1 of RSAs Essential Driver Training course. As a qualified and registered ADI I would be happy to book you in for a lesson, if required.
« Last Edit: November 04, 2022, 10:22:34 am by Rat Catcher »
Re: DPF problems.
« Reply #40 on: November 04, 2022, 12:24:38 pm »
Hi Steve My advice to Kenneth was to get a full diagnosis before fixing the Turbo I suggested going to his local Auto Electrician who usually have good diagnostic tools .Get a full print out of faults .Kenneth had three different problems and solutions offered by his Spanner Monkey .Turbo DPF and possible engine replacement .Auto Electrician wont be trying to sell him mechanical services .50 spent on a full diagnosis might be money well spent .
Offline MK
Re: DPF problems.
« Reply #41 on: November 04, 2022, 03:51:35 pm »
Where can you get full diagnosis for 50 john? I thought its over 90 or something. Suggest good auto electricians in Dublin
Re: DPF problems.
« Reply #42 on: November 04, 2022, 10:18:11 pm »
The BEST is the lad on the Cromwellsfort Road in Walkinstown facing the Chipper .Noel Byrne just off St Peters Road across from the Garage is good as well But the lad on Cromwells is the Best .ALMAX .
Re: DPF problems.
« Reply #43 on: November 05, 2022, 08:05:42 am »
I was thinking that too.
Oil and water checked at start of each month and always the correct oil used.
Re: DPF problems.
« Reply #44 on: November 05, 2022, 09:04:47 am »
Monthly oil checks are honestly just careless Belker.Bloke like you with your mileage and prior history of fukking up engines should be checking it weekly.This is your business.Unless you up yer game yer gonna keep ruining engines.Ya should change the thread title to owner driver doesn't give a bollox about his engine.
When ya say correct oil what exactly do you mean?Ya know there are multiple grades of engine oil and different weights depending on the manufacturer.
« Last Edit: November 05, 2022, 09:07:40 am by mercenary for hire »
