Author Topic: Dead out there - what's the story?  (Read 8351 times)
Re: Dead out there - what's the story?
« Reply #45 on: January 05, 2023, 04:26:04 pm »
What would the effect of bypassing the suspected faulty component be?
« Reply #46 on: January 05, 2023, 05:50:51 pm »
,,^^^^Octy I'd still take it up with the dealer.You were one of a few people who bought them new back in 2018.In the US it's covered under some emmisions warranty they have there I believe.It appears to be a known issue and your vehicle was built in the same factory.The Toyota dealer should push to head office to cover it as a goodwill gesture.Toyota are fairly defensive about their reputation.
« Reply #47 on: January 05, 2023, 06:43:28 pm »
This is the letter I got from Toyota head office regarding the inverter, perhaps the same rules apply to other components:
Good afternoon, Herr Bullet,
May we also thank you for your support of Toyota and for taking the time to contact us directly.
Please be advised we are only in a position to determine outstanding recall campaigns for vehicles distributed directly for the European market. We note from our correspondence, your vehicle was originally distributed for a market outside of Europe.
Therefore, in order to determine whether or not your vehicle is included in any outstanding campaigns, we would ask that you make contact with your nearest Toyota Main Dealer/Authorised Repairer who will complete a Private Export Campaign Information form based on your vehicle details.
The Dealership will then submit this form to our Campaign team who will liaise with Toyota in the originating country in respect of your vehicle.
Our campaign team will then revert to your Toyota dealer to advise.
Please follow the link to find the Toyota Dealer nearest to you.
Thank you for contacting Toyota Ireland.
« Reply #48 on: January 05, 2023, 08:46:57 pm »
 puttin it up on a hoist Tommoro...goin bypass it ...then I'll know for sure ...also mite be an external leak visible...an go on from ther ....
My experience wit the dealer is extremely negative ...
But you cud be rite ...maybe contact head office ...they'll tell me tho to bring it to the dealer for diagnosis...an I be better armed if I know absolutely before then
« Reply #49 on: January 05, 2023, 08:50:48 pm »
Fingers crossed that you get it sorted soon….You dont need that headache at the start of the new year…anyways you are on the case!
« Reply #50 on: January 05, 2023, 08:57:47 pm »
Takes longer to heat the car up Rat  ...an probly slite drop in economy because engine be colder for longer  ...but ide say nuttin to rite home about ...
« Reply #51 on: January 05, 2023, 09:05:14 pm »
Mite be few lads tinkin buyin this model coola  ...the imports are all these models  now ide imagine....
It mitent even be my problem but
Sometin to know  about ...if yu do buy one ...
It seems to be a common problem
« Reply #52 on: January 06, 2023, 07:30:03 pm »
 Rite ...Job done ...
hopefully it won't blow up ...but runnin well ...
them japenese....between ther heaps o shite an ther crypto ..... startin annoy me .... ::fight
Time for a nap zzzz ::sleep
« Reply #53 on: January 09, 2023, 02:42:10 pm »
If it works out you could establish a little sideline.
« Reply #54 on: January 09, 2023, 02:54:49 pm »
Had to make up a metal  u pipe .  But the one rubber one  I put up here wud of bean good to connect the other end ...but ther 3 weeks away from America an a fortune in post but probably worth it ...cudnt find one in Europe but ther sure to be ther
If yu know a friendly plumber he cud make a copper pipe up for ya ...16 mm u shaped to fit the hoses
« Reply #55 on: January 09, 2023, 02:57:07 pm »
Wats the story wit prebooks on fn ?
Thers nuttin on it ... ::sleep
« Reply #56 on: January 09, 2023, 03:00:35 pm »
Might be worth trying a bit of water mains hose for size. The external diameter is somewhat bigger at 21mm (fits IR 3/4" connections) but they are quite thick walled and, although rubber, would be stronger in terms of water pressure than copper.
« Reply #57 on: January 09, 2023, 03:33:22 pm »
Copper be alrite ide say  ...I used aluminium ...but a u shaped  auto hose 16 mm internal diameter be good at the other end
« Reply #58 on: January 10, 2023, 05:02:08 pm »
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=371016178306&category=180380&pm=1&ds=0&t=1673178049000&ver=0&cspheader=1
Perfect pipe ...to bypass the heat exchanger...I've ordered ....
No coolant loss since   O:-)
Car runnin perfectly
« Last Edit: January 10, 2023, 05:09:21 pm by Octavia1 »
