Author Topic: Finally Gone Electric.  (Read 1117 times)
« on: July 30, 2023, 02:07:51 pm »
Changing the brake fluid in both my and Mrs. Catcher's cars was scheduled for April this year so, well overdue. Not having a lift and/or the hands of a 6 year old dictates that I have to remove each roadwheel in sequence making it quite a tedious job. Anywaysanall, whilst sitting on the Priorwood Rd unofficial rank one evening I had a browse of a Lidl catalogue a client had left on the back seat. An impact wrence for €89.99 caught my eye. Can't be up to much at that price I thought to myself but decided to give it a try and finally do the brake fluid job with a view to returning it if not entirely satisfied - in essence I was expecting to borrow it, I guess... so I had a look in the new Lidl in Coolock, none in stock but, as happens when one browses the middle aisle I bought a tap and dye set (@€14.99) I have absolutely no use for and a cordless circular saw for €44.99 caught my eye - my 20 year old Argos corded one needs new brushes every time I use it nowadays - but, on closer inspection it was a bare unit i.e. the (20V - beware there's a cheaper and totally useless 12V model too!) battery would have cost another €40 and the charger the guts of €15 so I decided against, however thinking I might have a look for the impact wrench in another store and buy both if the battery/charger was the same. So, last Wednesday I was up in the United Kingdom of Great Britain and Northern Ireland so decided to have a quick look in their Lidl. Bingo, there was the impact wrench for stg£65.99 (c.€75) and the battery (4AH battery and fast charger included) did match the requirements of the saw - x20 series, which I had committed to memory. Alas they had no saw in stock... in fact, I looked in several other stores both north and south and concluded that the Coolock store (the one beside The Range) was the only place I could get it... so I did on Thursday.
Thursday afternoon I decided to do the brake fluid and play with my new toy. As soon as I had a jack under the first wheel a neighbour was out enquiring what I was doing and on being told went back to his gaff only to arrive a couple of minutes later with a brand new Milwaukee impact wrench he'd spent a monkey on for his garage. Bollox, says I... I want to play with this one, showing him my Lidl machine. Pff, says he... use mine to take them off and use that to put em back and see what torque you get - later coming back with a torque wrench. Needless to say his machine pissed through the removal job where the Lidl one failed to remove either of the two bolts I tried it on but I did use it to replace the bolts as suggested and measured the torque concluding that it just about reached manufacture specifications at 120NM but got nowhere near the advertised 4xxNM. The saw probably isn't as powerful as my electric one (the one that eats brushes as fast as the erm devours hot dinners) but is sufficient for occasional DIY jobs and, being cordless, ideal to bring to the local mercantile if buying lengths of timber that need cutting to fit in the car. Conclusion, at the prices I might as well hold on to both tools but I'll not be disposing of either my old electric saw or my knuckle bar!
« Last Edit: July 30, 2023, 02:21:06 pm by Rat Catcher »
Re: Finally Gone Electric.
« Reply #1 on: July 30, 2023, 02:31:35 pm »
Those Lidl things just speed the process along.I thought I'd get a new interest in taxi DIY once I bought the Lidl impact wrench but I've only used it a few times to remove nuts after their been broken loose and spin them back on after the wheels have been off.
One with a plug might have a bit more power.
« Reply #2 on: July 30, 2023, 02:45:32 pm »
Probably but for the amount of use I'll give mine it'll suffice. It's no big deal to crack the bolts first but you'll not be reaching for it to shift a bolt you can't remove with a small rachet! I probably would have returned it if I had bought it this side of the border (and tried the one below from Amazon, again with a view to returning) and the battery and charger (for the saw as well) weren't in the box... but to buy the battery and charger would cost €55 so I can conclude that the impact wrence was only a score!
Amazon option (main difference being an extra volt, slightly higher "specified" torque @ 550NM and a brushless motor):
https://www.amazon.co.uk/gp/product/B0BC8FRW5H
c.€87 (stg£99.97 less £25 voucher for ticking the relevant box)
« Reply #3 on: July 30, 2023, 03:02:01 pm »
"So, last Wednesday I was up in the United Kingdom of Great Britain and Northern Ireland"
Here you ....stop that ...or yull be gettin an impact wrench all rite  ::fds
« Reply #4 on: July 30, 2023, 09:45:34 pm »
Bought one myself, reason being I’ve suspension work booked in for my 1992 Carina E, spring compressors are a cunt to use when using a 1/2 drive ratchet, the impact wrench makes it so much handyier.
« Reply #5 on: August 03, 2023, 11:35:40 am »
No wonder they had none left in the rip-off Republic with yisser all snapping them up. Still, I save 15 notes on mine and (potentially) saved myself from future middle aisle "bargains" as I'll be checking the United Kingdom catalogue price (available on tinternet) on anything that cathches my eye going forward and will be reluctant to spend 20% more than charged a few miles up the road.
« Reply #6 on: August 03, 2023, 03:35:47 pm »
Do you carry a stock of British Parnds? Better still, get a professional to do the work and write it off against tax. 8)
« Reply #7 on: August 06, 2023, 12:35:50 pm »
You can't write it off against tax. You can deduct it in your computation of taxable profit, potentially reducing your income tax bill by 20% of the amount spent. However, you may only deduct business expenses in computing net profit which (in my case) would not extend to maintenance of Mrs. Catcher's vehicle. Of course you can deduct expenditure on tools required to maintain your vehicle, leaving you with something to show for your money.
If you want a job done properly do it youself... or pay the extortionate rates charged by a main dealer, happy in the knowledge that the tax man is paying 20% of it!
« Reply #8 on: August 06, 2023, 05:06:49 pm »
It'll all end in tears, although safe in the knowledge you did it yourself.
« Reply #9 on: August 06, 2023, 05:25:19 pm »
Is your L car an EV?
Home charging on the cheap:
« Reply #10 on: August 13, 2023, 11:23:14 am »
Its shocking
