Author Topic: Is this our next panic  (Read 786 times)
« on: September 05, 2023, 07:27:59 am »
If they used it in Britain they must of used it here ...What is RAAC?
Reinforced autoclaved aerated concrete (RAAC) is a lightweight material that was used mostly in flat roofing, but also in floors and walls, between the 1950s and 1990s.
It is a cheaper alternative to standard concrete, is quicker to produce and easier to install.
It is aerated, or "bubbly", like an Aero chocolate bar.
But it is less durable and has a lifespan of around 30 years.
Its structural behaviour differs significantly from traditional reinforced concrete.
Moreover, it is susceptible to structural failure when exposed to moisture. The bubbles can allow water to enter the material.
If that happens, any rebar reinforcing RAAC can also decay, rust and weaken.
Because of this, RAAC is often coated with another material, such as bitumen on roofing panels. But this material can also degrade.
The Standing Committee on Structural Safety (SCOSS) noted that: "Although called 'concrete', RAAC is very different from traditional concrete and, because of the way in which it was made, much weaker."
According to Loughborough University, there are tens of thousands of these structural panels already in use and "many are showing signs of wear and tear and deterioration".
The Health and Safety Executive says RAAC is now beyond its lifespan and may "collapse with little or no notice".
DID our Government know about this Why did they pull down Ballymun and St Michaels Estate ?Imagine if this Concrete was used in the Old Shannon or Dublin Airports ?Probably explains why they part remodeled the Legoland Houses with Flat concrete roofs in Cherryorchard and Old Bawn ?
Re: Is this our next panic
« Reply #1 on: September 05, 2023, 09:18:03 am »
Department of Education says aerated concrete material not used in Irish schools
The Department of Education has said it is not aware of any potentially dangerous concrete material used in schools in the Republic.  <snip> A spokesperson from the Department of Education said: "The Department of Education is aware of the concerns in relation to schools in England that have reinforced autoclaved aerated concrete (RAAC) materials.  "The Department is not aware of these materials being used in schools in Ireland.
"The Irish Concrete Society has indicated to the Department that it has no knowledge of the use of this material in Ireland."
And any evidence otherwise is probably buried under 6 foot of, err, concrete  ::)
« Reply #2 on: September 05, 2023, 11:16:24 am »
Yessers….have enough to worry about? O:-)
« Reply #3 on: September 05, 2023, 02:51:06 pm »
We're too busy building resulting in Pyrite and Mica, and then blaming the government instead of the blockmakers and developers.
This is how you deal with rogue developers:
https://www.dailymail.co.uk/news/article-12457087/Venezuelan-narco-body-dumped-Caribbean-Sea.html
« Reply #4 on: September 05, 2023, 03:39:40 pm »
Bullit your Girl would understand this product .It was popular for gyms and large open spaces where they did not want obstructions .It was light weight then covered in Asphalt .My old Man worked with Precast Concrete from the 60s until he retired .The big builders in the 60s in Ireland were off shoots of Brit Companies Laings .Walls .Whimpey .if it was used in the UK it was used here .If you were building up like Liberty Hall this light weight concrete would make sense for the flooring .Probably safe as houses ???? as it cannot get wet .They recon this stuff is like a bar of aero full of holes to reduce weight but if the eater gets into it the reinforcing will rust swell and crack the concrete .If bogey hardcore was delivered to the Gaffs out near the Airport was the same hardcore delivered for runways or foundations in the Port 2 .
