Author Topic: Did you work this morning or 'tis only a bit of snow?  (Read 1556 times)
Re: Did you work this morning or 'tis only a bit of snow?
« Reply #15 on: March 01, 2024, 11:18:40 pm »
I did OK last night. Ironically dropping at St David's terrace behind MET EIREANN.
Yes, it was lashing, but no snow up to 05.00 when I decided to call it a night.
Ha, I even got a 20-dollar tip off a Sherman. Who couldn't find Lorcan Road from San-sans, so I dropped him around for free.
He then said can I give you a 20-dollar tip? I said why of course! 8)
« Reply #16 on: March 01, 2024, 11:28:02 pm »
The " B " gear engages engine compression hal .....its used in snow or ice cause it requires less brake pad effort or application that  can  cause fluctuations sort o ting  an can skid the cunty ting or engage the abs ....or down a mountain to prevent brake fade wer the degenerate brakin has gone beyond its limits...sort o ting ....its a safety ting sort o ting  lol
« Last Edit: March 01, 2024, 11:31:28 pm by Octavia1 »
« Reply #17 on: March 03, 2024, 12:29:56 pm »
B in Toyota Automatics/Hybrids is Engine Braking. It's designed to prevent excessive coasting when descending hills under braking... hence I guess it probably increases control over the vehicle in snow/ice also.
