Author Topic: Do you know how ?  (Read 4110 times)
Re: Do you know how ?
« Reply #15 on: May 29, 2024, 11:59:56 am »
Switch on either of the +/- leads, Ken. I repurposed my old roof sign switch to further improve the environment. Another option is to switch off the ignition for a few seconds after every job (AFAIK all SDA installations have the meter switched through the ignition) but that'd be a right pain in the bottom, IMO.
Mine's a Hale Microtax 5 (as is Ken's unless he's changed it recently) Horse and the switch works fine. I only almost ran out of paper* because I relocated my printer inside a little mini glove box and forgot to switch it off after an extremely rare request for a paper receipt - out of sight, out of mind.
* have to catch mine before the roll expires 'cos the feeder buttons don't work anymore so, bar taking the thing apart, the new roll needs to be fed behind the old roll and a receipt reprint carried out. Fortunately it generally only needs changing when it goes yellow, after c.2.8 years.
« Reply #16 on: May 29, 2024, 01:30:24 pm »
Just to clarify, Ken. I should have said AFAIK all SDA installations have the printer (not the meter) switched through the ignition i.e. they wire the printer to an ignition switched circuit. The meter is wired to a constant circuit... in both cases seemingly randomly cutting into existing circuits with no regard for the consequent over-current warnings generated by the vehicles OBD systems!
« Reply #17 on: May 29, 2024, 05:12:17 pm »
With the semitron ones you just have to leave the little door ajar and it doesn't print. Just close it when you need one. The hale used to do my head in. The meter won't work unless there's paper in it so you have to print a receipt every time. Such a waste of paper as only one in every 20 or so want a receipt.
Same with the ATA meters, just leave the door a bit ajar.  Just bought my 2nd roll after ~3 years!  I actually bought two - just in case  :P
They should change the rule.  I only get a request for a paper receipt maybe once a year.  People who need a receipt almost always use an app or pay with card.
« Reply #18 on: May 29, 2024, 08:18:15 pm »
I tell punters to always ask for a printed receipt, no receipt = a free trip. Or a trip to the Garda station. They're operating illegally
« Reply #19 on: May 29, 2024, 09:47:40 pm »
My new Taxitronic Mirror Meter won't return to For Hire unless there's paper in it...the printer is built in to the Meter.
« Reply #20 on: May 30, 2024, 09:45:40 am »
Ran out of rolls and had none in new car so had to reuse the old paper by rolling it back on to the roller.Recycling the paper Eamo would be proud of me .
« Reply #21 on: May 31, 2024, 07:19:00 am »
Grab me a till roll ifn you're in there, Octy. I had to install the last of the three I got off them 7 years ago last night.
How do you manage to stop the printer printing a receipt every time ?
If you haven't fitted a switch to knock it off, take the roll off the feed system until you need a receipt.
I used to have a switch fitted but had to take it out fer the last car change over in 2020 as my meter guy would not do any NTA work on an illegal meter, which as it happened was a blessing because the suitability inspector at the intial suitability test that year was all over the meter checking every side of it. I never bothered putting the switch back on after that.
Also my printer feeder does not work similar to what Rat Catcher posted earlier.
« Reply #22 on: May 31, 2024, 07:20:33 am »
I have a hale meter and printer and the meter will operate without paper.
« Reply #23 on: May 31, 2024, 07:25:18 am »
On my old 08 that was the case and I could turn off the ignition to stop the meter printing but after the meter being re-fitted to my nua cab in 2020 that does not work anymore and a receipt is issued every time.
« Reply #24 on: May 31, 2024, 07:45:57 am »
..... Mine's a Hale Microtax 5 (as is Ken's unless he's changed it recently) .....
.... have to catch mine before the roll expires 'cos the feeder buttons don't work anymore so, bar taking the thing apart, the new roll needs to be fed behind the old roll and a receipt reprint carried out.
I do still have the Hale microtax 5 which also has a broken printer feeder and do as you do above.
I have been caught a few times with the roll running out and have tried various methods to get the roll back through.
What works fer me (after much anguish over the years) is to use a thin piece of cardboad about the size of a credit card and then double over the end of the receipt roll over the slot inserting the paper sized CC in to the fold and ramming in it to the printer.  Does that make sense ??
What I use is the paper card the bank sent me years ago with my account number on it. It'a fine balacing act because the plastic CC is too big and oviousley you cant ram anything in with a piece of flimsy plain paper.
« Last Edit: May 31, 2024, 08:03:22 am by Belker »
« Reply #25 on: May 31, 2024, 07:59:44 am »
I gave up trying to bypass the meter printer fer reasons stated above.
Today I just buy 100 at a time online from discount till rolls which is a Dublin-based company.
100 rolls cost me 60 Euro the last time I bought them which works out at .60 cent per roll.
https://www.discounttillrolls.ie/taxi-supplies/
« Reply #26 on: May 31, 2024, 11:53:51 am »
My hale absolutely did not work without paper in the printer Ken. The metre simply said no paper and would change until I fed paper into it. Poxy piece of crap. Glad to see the back of it. My semitron mirror metre would kick the shit out of the horrible hale's.
« Reply #27 on: May 31, 2024, 01:49:58 pm »
How much was the Taxitronic Mirror meter and printer Hal?
Irish websites don't like putting up prices. I think they were all born in Cavan.
« Reply #28 on: May 31, 2024, 07:04:25 pm »
Big Dommos cousins girlfriends gay mates sisters best friend works in a corner shop near the chipper beside the flats and I get the rolls for the credit card machines off of her because she likes me .They fit the printer.
« Reply #29 on: June 03, 2024, 10:29:24 am »
......  What works fer me (after much anguish over the years) is to use a thin piece of cardboad about the size of a credit card and then double over the end of the receipt roll over the slot inserting the paper sized CC in to the fold and ramming in it to the printer.  Does that make sense ??
To Stephen, a small amendment to what I stated above, it is actually a 'Gift of Life' paper donor card that I use to help insert the new roll in to the Hale printer and not the paper bank card. The paper Donor card is the perfect size fer the above procedure.
If'n your intent on applying fer such then maybe best not to mention that you require the paper Donor card fer Taxi meter printer repair problems ??
Anyways'n'all you can get them here fer Free;
http://www.organdonation.ie/donate.html
