Author Topic: Do you know how ?  (Read 4108 times)
Do you know how ?
« on: May 25, 2024, 08:43:27 am »
When a passenger calls me on Freenow I cannot answer their call as my phone only rings but does not offer me a way to answer .Any suggestions on how to fix this .
Re: Do you know how ?
« Reply #1 on: May 25, 2024, 09:22:27 am »
Usually  i see a little 1 inch  bar at top that I tink it  says
 " answer" ?
« Reply #2 on: May 25, 2024, 09:26:10 am »
That happens if I get a call from a non customer but if the customer tries to call in app I cannot answer it .
« Reply #3 on: May 25, 2024, 11:20:26 am »
If your phone is synched to the MG5, the answer/hang-up buttons are on the centre console screen?
Alternatively, text them that you're deaf so can't take a phone call  :P
Online Punter
« Reply #4 on: May 25, 2024, 02:03:37 pm »
Did you get the question "GIVE FREE NOW ACCESS TO CALLS "--
Check settings --go into Apps and check permissions !
« Reply #5 on: May 25, 2024, 02:27:23 pm »
Had to press the bluetooth symbol on my phone nua, if memory serves. In any event, whatever I did, it works now so give support a call or drop in to the depot if you can't figure it out through trial and error.
« Reply #6 on: May 25, 2024, 04:45:55 pm »
I wudnt go fukin near them ....they mite hypmotise him or sumtin .....he mite come out of ther office a licky lacky  lick arse ....
« Reply #7 on: May 26, 2024, 11:27:56 am »
 rofl rofl rofl
« Reply #8 on: May 28, 2024, 11:26:54 am »
Grab me a till roll ifn you're in there, Octy. I had to install the last of the three I got off them 7 years ago last night.
« Reply #9 on: May 28, 2024, 11:31:27 am »
 ::sleep ::sleep ::sleep ::sleep ::sleep
How does she put up wit yu  ::fight
« Reply #10 on: May 28, 2024, 11:47:08 am »
Laffin  rofl rofl rofl
« Reply #11 on: May 29, 2024, 05:03:18 am »
How do you manage to stop the printer printing a receipt every time ?
« Reply #12 on: May 29, 2024, 06:48:16 am »
If you haven't fitted a switch to knock it off, take the roll off the feed system until you need a receipt.
« Reply #13 on: May 29, 2024, 09:00:56 am »
I put tape over the little white sensor inside the printer under where the roll goes which seems to work.Otherwise the meter will stay on "printer busy" message.To get it printing again I just install the roll quicky every couple of days as needed.
Some on here have gotten similar results by leaving the printer door partially open.Apart from the fact that paper has gotten much more expensive like a lot of stuff the car fills up with paper after a week's work so it's worth trying to sort.
« Reply #14 on: May 29, 2024, 09:52:17 am »
With the semitron ones you just have to leave the little door ajar and it doesn't print. Just close it when you need one. The hale used to do my head in. The meter won't work unless there's paper in it so you have to print a receipt every time. Such a waste of paper as only one in every 20 or so want a receipt.
