Author Topic: Rat Run  (Read 9186 times)
Rat Run
« on: February 06, 2019, 11:16:15 am »
Rat run in Rathmines is now one way from half way .You can no longer go from the canal up to Palmerston Road .
Re: Rat Run
« Reply #1 on: February 06, 2019, 11:19:45 am »
whew... I thought that was a suggestion.
Re: Rat Run
« Reply #2 on: February 06, 2019, 11:21:09 am »
Has been for about 3 months
Re: Rat Run
« Reply #3 on: February 06, 2019, 11:23:38 am »
The erm's only been sober for one.
Re: Rat Run
« Reply #4 on: February 06, 2019, 11:26:33 am »
Should visit the southside more often, welcome anytime JM
Re: Rat Run
« Reply #5 on: February 06, 2019, 11:32:31 am »
Its a South City thing Rodent you wouldnt understand but its a total pain if you are traveling down the canal for Renalagh .You use to go right  left  right  but now you have to go left,left right through the lights past Roddies then left round the Chapel down to the lights left righ left .I hope its not a question on the test .Or alternatly you could continue on down the canal past the no turn turn for Renalagh and just under the Luas bridge there is a small laneway turn right ,right  then left  onto Renalagh .Hope this helps or an alternative to the alternative you could turn off the canal at Rathmines go left ,right at the bleeding Horse right at the luas line sharp left and straight up to Renalagh .
Re: Rat Run
« Reply #6 on: February 06, 2019, 11:35:19 am »
Dublin 8,10,12 is my plot .I spend more time in Spain every year than I spend in Harcourt or Leason Street combined
Re: Rat Run
« Reply #7 on: February 06, 2019, 11:36:33 am »
I was over in Ballyfermot last evening... mytaxi fare from Darndale... had that lost connection problem again... didn't get back on line until I was on one of the North Quays... then the passenger cancelled box popped up... fortunately it was a cash job so the cancellation saved me €4.20 in freight... compensates for that no contact they refused to pay me the year before last, I guess.
Re: Rat Run
« Reply #8 on: February 06, 2019, 11:37:57 am »
Palmerston.....handjob park past Garret Fitzs old gaff. Lively spot after midnight.
Re: Rat Run
« Reply #9 on: February 06, 2019, 11:40:17 am »
you should of rang I  would of watered or fed you .
Re: Rat Run
« Reply #10 on: February 06, 2019, 11:49:09 am »
do ye mean up mount pleasant.
it might be just one of those you can't turn left at certain times signs.
Re: Rat Run
« Reply #11 on: February 06, 2019, 11:51:53 am »
It was getting towards home time, erm... was gonna watch that BBC2 programme where 3 budding restauranteurs compete for investment... however, I was too tired when I got in shortly after midnight so I'll watch it this afternoon instead.
Re: Rat Run
« Reply #12 on: February 06, 2019, 11:53:46 am »
Yep top end is now one way
Re: Rat Run
« Reply #13 on: February 06, 2019, 02:47:50 pm »
I used to go for a walk before school with my daughter in that park,until the day she found a large condom wrapped banana on the ground.
Re: Rat Run
« Reply #14 on: February 06, 2019, 02:52:51 pm »
How else do yis keep bananas fresh?
