Author Topic: Failed NCt  (Read 28319 times)
Re: Failed NCt
« Reply #30 on: February 20, 2019, 04:37:08 pm »
Mine is a toyota avensis
Re: Failed NCt
« Reply #31 on: February 20, 2019, 04:40:11 pm »
What yr, Dalyer............last Avensis I had had a belt
Re: Failed NCt
« Reply #32 on: February 20, 2019, 04:42:06 pm »
There you go......Fucking VAG...........money-pits.
Not as bad as you might think. My MKII Octy cost €2,899 to maintain for the 5 years I used it as a taxi. They're certainly not as well built as Toyotas but then they're a lot cheaper to buy.
Re: Failed NCt
« Reply #33 on: February 20, 2019, 04:47:29 pm »
Its  13 lippy
Re: Failed NCt
« Reply #34 on: February 20, 2019, 04:51:30 pm »
Diesel? The Merc brand always promised no change for the chain but that was 20 yrs or so ago I think.
Re: Failed NCt
« Reply #35 on: February 20, 2019, 05:06:28 pm »
Yeah its deisel.um just trying to get some idea what kind of money we are talkiing about,or even if it can be repaired,rather then replaced
Re: Failed NCt
« Reply #36 on: February 20, 2019, 09:03:26 pm »
Audi's have timing chains afaik.
Re: Failed NCt
« Reply #37 on: February 20, 2019, 10:47:12 pm »
Nearly 300,000 k on it Stephen .I was like you ,I didnt think sohe neither, but there seens to be a skight nouse whwn starting from cold
And what about the car?
Re: Failed NCt
« Reply #38 on: February 20, 2019, 10:48:37 pm »
As you may have guessed I'm not a happy camper today.
Went for me NCT and the cnut failed me on a "Frayed/Cut CV Boot".
My mechanic had checked this only last week and all looked Ok, bit a wear.
I'm convinced the NCT'r used his mickey to Fray and cut it
Change both.
Should take less than an hour.
Re: Failed NCt
« Reply #39 on: February 22, 2019, 09:41:48 pm »
Could just be the fan belt or the tensioner! Check the simple things first apbefore thinking of big expenses.
Unless of course your mechanic said that it’s the timing chain.
I use the NCT to tell me what’s wrong with my car
And a cv boot can look ok to your mechanic one day but the next it can be torn, also the boot might have been dirty when your mechanic looked at it and you then washed the underneath for the NCT
Re: Failed NCt
« Reply #40 on: February 23, 2019, 01:20:23 pm »
Wash the underneath... fuck off!
Re: Failed NCt
« Reply #41 on: February 23, 2019, 08:12:43 pm »
Some fancy car washes do that
Re: Failed NCt
« Reply #42 on: February 23, 2019, 10:49:39 pm »
A good wash.. will sort yaa
Re: Failed NCt
« Reply #43 on: August 20, 2019, 11:39:13 am »
Went for NCT again yesterday, failed on Imbalance on Front Suspension, 2 new shocks for me 07 Avensis, should see me through until It has to retire in 2022, or I die before then
Re: Failed NCt
« Reply #44 on: August 20, 2019, 11:56:13 am »
If your running anything over 5 years put aside 500 for running repairs .We abuse cars probably go over a million or more speed bumps a few hundred thousand pot holes clatter foot paths a five year old taxi is equivlent to a ten year old civilian motor .its just another cost of trying toearn a living .
