Author Topic: Suitability Failed -Puncture device  (Read 9770 times)
Re: Suitability Failed -Puncture device
« Reply #30 on: March 05, 2019, 03:26:25 pm »
Taximen -vs- taxi drivers... I wouldn't take a child's pram out without a spare.
My car is modern, Watty. It's an oh16 FFS... and it has a full size spare wheel.
« Reply #31 on: March 05, 2019, 03:30:16 pm »
Yis should buy a plug kit.I had two punctures in the last week.It's faster to fix it than take off the wheel and drop it in to get fixed.Ive considered leaving my spare at home as I never need it.
« Reply #32 on: March 05, 2019, 03:32:26 pm »
Tyre was fucked last time I got a puncture... and the time before that... can't remember the last repairable one I got. Who sells these kits anyway, could be next year's post-Xmas gifts sorted. I'd imagine it's just a few plugs and a bradawl?
« Reply #33 on: March 05, 2019, 03:45:38 pm »
How you find the hole ?
« Reply #34 on: March 05, 2019, 03:45:56 pm »
The one I bought was from Ebay years ago.I'm sure you can buy them here for five times the price.Some stuff I've read says that they're only temporary solutions but I've never had one fail.I've used it over ten times so far.
https://m.ebay.ie/itm/11pcs-Tire-Repair-Kit-Box-DIY-Plug-Heavy-Duty-Patch-Car-Truck-Tubeless-Wheel/123259304254?hash=item1cb2d3b93e:g:-x4AAOSwrFxbUEyD
« Reply #35 on: March 05, 2019, 03:49:26 pm »
^^^^^^STC it's almost always a wood screw.You pull it out with a pliers and bore the hole out with the tool then insert the rubber yoke, that needs a bit of muscle, then cut the surplus off with the Stanley that's included.Just did one this morning.
« Reply #36 on: March 05, 2019, 03:53:57 pm »
As far as I know there are no plugs,or bradalls involved .you simply put the nozzle of the tin over the valve where tou put in the air,and the white foam inside the tin just plugs the puncture till you get to a reppair shop
« Reply #37 on: March 05, 2019, 03:56:30 pm »
That's the can, DM. I got one of them for post-Xmas this year... It's the plug kit that MfH is on about that I was referring to.
« Reply #38 on: March 05, 2019, 03:57:43 pm »
Bit pricey for post-Xmas gifts... might buy one for myself though!
« Reply #39 on: March 05, 2019, 04:02:42 pm »
I just got fed up with the tyre shops saying they're too busy or drop back later.At least now I won't have to put the yellow space saver on.
« Reply #40 on: March 05, 2019, 04:03:12 pm »
As MFH,i have a plug kit and a decent 12v air compressor....i wouldn't put one of those sealant cans near my car....not even next to it!!
« Reply #41 on: March 05, 2019, 04:11:46 pm »
Oh yeah forgot to mention the compressor!I got one out of a Maxol for less than a tenner a few years ago.I have had limited success with the sealant foam in the past.
« Reply #42 on: March 05, 2019, 04:14:47 pm »
Ok MFH I understand had this done many a times, BUT what about when it don't fall in to the "Almost Always" category, how you find the hole if the screw don't exist ?
« Reply #43 on: March 05, 2019, 04:17:55 pm »
Bring it to Glen or Collin.
« Reply #44 on: March 05, 2019, 04:20:49 pm »
^^^^^I had a hole once with nothing stuck in it.To find it I poured water(volvic)over the tyre whilst pumping it up with the compressor to find the bubbles.Just like putting a bicycle tube in a basin.
