Author Topic: NCT test  (Read 6050 times)
Re: NCT test
« Reply #15 on: June 03, 2022, 01:21:48 pm »
Why do mean Billy?I done Dublin to Kerry mine and it only used about 25/30 euro worth of Fuel.
« Last Edit: June 03, 2022, 01:33:23 pm by mercenary for hire »
Re: NCT test
« Reply #16 on: June 03, 2022, 06:43:37 pm »
Can't agree there BB!!
Re: NCT test
« Reply #17 on: June 03, 2022, 07:04:39 pm »
Maybe in a Camry, certainly not in a Prius.
Re: NCT test
« Reply #18 on: June 10, 2022, 08:13:48 pm »
Service this morning + 2 wipers + 2 bulbs + rotate tyres and tracking €238.
Passed the Free NCT, just Suitability to go and I know a lot of my bandages are out of date,
can ya buy a first aid kit somewhere ?
Re: NCT test
« Reply #19 on: June 10, 2022, 08:19:17 pm »
https://www.boots.ie/boots-complete-first-aid-kit-10258544
Just check the kitemark/ISO.
Re: NCT test
« Reply #20 on: June 10, 2022, 09:55:54 pm »
Boots complete First Aid Kit contains:
    3 x Self-Adhesive Wound Dressings 8cm x 6cm
    Eyewash 20ml
    Crepe Bandage 7.5cm x 4.5m
    Resuscitation Face Shield
    Fabric Plaster Strip 6cm x 1m
    Eye Pad Dressing
    6 x Assorted Safety Pins
    Instant Ice Pack
    Calico Triangular Bandage
    Large Sterile Dressing 18cm x 18cm
    3 x Low Adherent Dressings 10cm x 10cm
    Heat Retaining Foil Blanket
    5 x Sterile Wound Cleansing Wipes
    Conforming (Stretch) Bandage 7.5cm x 4m
    2 x Medium Finger Bandages
    20 x Washproof Plasters
    Microporous Tape 2.5cm x 5m
    3 x Burn Gel Sachets 3.5g
    1 Pair x Powder Free, Non-Latex Gloves - Large
    First Aid Guide
    First Aid Scissors
    Tweezers
This is the list, photo taken in the suitability center.
« Last Edit: June 10, 2022, 09:58:34 pm by Belker »
Re: NCT test
« Reply #21 on: June 10, 2022, 10:03:01 pm »
When do ye need it for Ken....I'll be down in Cork on the 26th...I can pick one up for ye from Stuart in Mechanic 24.
Re: NCT test
« Reply #22 on: June 10, 2022, 10:15:54 pm »
Do that please Hal, I'll sort ya out when your down South.
Re: NCT test
« Reply #23 on: June 10, 2022, 10:46:03 pm »
To clean or not to clean .I usually power wash the car including underneath when I go for the NCT my thinking it shows a bit of respect to the person having to inspect it ,but Big Dommo recons if you clean it they can get a better look and find more faults like worn rubbers or boots ? So what do you recommend clean it or leave it ? Upside of a good clean for the NCT is its done for the Suitability a few days later !
Not nessesary
Online watty
Re: NCT test
« Reply #24 on: June 11, 2022, 07:46:11 am »
Probably overkill to clean the underside every year. I think the official line it has to be clean enough that the tester can see everything. Maybe clean the underside every second year?
I've never seen a suitability tester look under the car.
Re: NCT test
« Reply #25 on: June 12, 2022, 12:14:19 pm »
When you say rotate the tyres do you mean swap the fronts with the backs? If so why do you do that? Just buy new front tyres ye hungry git. Can't see the logic in doing that. Next time around you'll need 4 tyres.
Re: NCT test
« Reply #26 on: June 12, 2022, 12:18:51 pm »
Front tyres wear roughly twice the rate as the back ones do, so yes it makes sense to rotate and just buy two at a time once a year depending on your milage of course
Re: NCT test
« Reply #27 on: June 12, 2022, 12:21:33 pm »
My tyres rotate themselves  lol
Re: NCT test
« Reply #28 on: June 12, 2022, 12:21:40 pm »
I do buy 2 at a time once a year. 2 front ones. The backs last about 3  years. Why would one take half worn tyres and stick them on the back? As I said, next time round you've to get 4 tyres.
Re: NCT test
« Reply #29 on: June 12, 2022, 12:22:42 pm »
As does your brain by the looks of it.
