Author Topic: best way to fix door stickers  (Read 4571 times)
« on: February 18, 2019, 08:26:00 pm »
one of my door stickers is starting to come off, i was going to use strong glue but would that be too strong and end up doing more damage than good?
Re: best way to fix door stickers
« Reply #1 on: February 18, 2019, 09:24:52 pm »
I took the old ones off my yoke wen it went to scrap..... It stripped most of the paint off wen I peeled it.....
If it's an owl banger wit a year or 2 left.... Glue probably not matter.... And if you need new sticker it's going cover it anyway.... Don't know if I'm helping or confusing..... I'm perpetually muddled meself these days
« Reply #2 on: February 18, 2019, 09:36:42 pm »
This stuff be better than superglue.... Wen i used work on the buses we used it to glue everything.... Temperature water resistant...lasts for years
« Reply #3 on: February 18, 2019, 09:47:52 pm »
As Octy said it depends on the age of the car, the sticker when it comes off will destroy the paintwork.
If you only have 2 or 3 years left then glue it or use Double sided adhesive tape from Woodies.
If ya have 4 or more years left then replace the sticker as it will keep peeling.
« Reply #4 on: February 18, 2019, 10:08:04 pm »
cheers lads. i have a good few years left.
will be running it into the ground though.
« Reply #5 on: February 18, 2019, 10:29:00 pm »
If'n ya have a good few years left then replace the sticker, and don't go fer the cheapest option or you will be replacing it again in Two years time.
« Reply #6 on: February 18, 2019, 11:31:26 pm »
Get a hair drier heat the decal and lift it .Then clean behind the dit that is lifting remove the dirt then clean the inside of the decal with a cotton bud and white spirit when it is klean use hair drier  and to heat it and credit card to rub it into plae should be ok
« Reply #7 on: February 19, 2019, 05:17:14 pm »
Peeling the old one without heating (hair dryer works fine) will take the paint off. In recent discussions we found two methods of removing the residual gum (mainly around the edges) - one is to spray with WD40 and rub/gently scrape off (thanks to Hal) and the other is to use bits of the old sticker, heating as you apply (thanks to Vikkiz).
« Reply #8 on: February 19, 2019, 07:45:44 pm »
Paint only comes off bad repairs.
« Reply #9 on: February 20, 2019, 01:45:25 am »
Just remove it using a hairdryer on medium or high heat....and get a new one fitted for €30.
« Reply #10 on: February 20, 2019, 11:02:49 pm »
+1
« Reply #11 on: February 22, 2019, 08:48:38 pm »
+1
+2
I also picked some of this up in Lidl few weeks ago.
