Author Topic: Light Duties  (Read 6190 times)
Light Duties
« on: September 13, 2022, 09:20:26 am »
Going to do me 3 hour shift last night but I only had one headlight bulb blew as I started the engine .I didnt go to work .Dont want to be driving around with Nodger or Willier in me car smelling of Hippy Cabbage and get stopped by the Gards the lads might not be best pleased if I draw attention to them .How many of you would stop working if your lights stopped working ?
Re: Light Duties
« Reply #1 on: September 13, 2022, 09:39:00 am »
I always did ...carried them headlight  bulbs that used to go all the time on the octavia  ...pain in the hole ...thankfully all that shite is a ting of the past wit the prius ....Still has the original brake pads .. ...no more new  flywheels every 2 yers or timing belts bollix or alternators or brake discs etcetera etcetera etcetera
Re: Light Duties
« Reply #2 on: September 13, 2022, 09:44:10 am »
The Occi bulbs were easy to change you need a box of bits from lidils middle isle to change the renault .I just changed a bulb last week and never bought a few spares I usually have a few in me first aid kit .I would not work in half light but I see plenty of taxis  with just the one .I would not like to be pulled over by gards for no light and have the wrong people in the car they might see you as the cause of their distress if any .
« Last Edit: September 13, 2022, 09:53:48 am by John m »
Re: Light Duties
« Reply #3 on: September 13, 2022, 10:02:20 am »
Seen a chap working with the space saver on the front the other day.I couldn't do that shit.
I have the Prius ten years and only changed the second of my original headlight bulbs the other day.I'm fairly sure that was one of the factory bulbs and it's a 2006 car.It wasn't easy but changed it in 15 minutes.You'd need the hands of a toddler to do it faster.
Re: Light Duties
« Reply #4 on: September 13, 2022, 10:09:11 am »
You need to pull out the whole headlight unit to get at the Renault and three different drivers to open the bolts .Lad in Wheels in Palmerstown shopping center will do bulb and fitting for a tenner .
I once saw a taxi with the boot lid held down with rope .
Re: Light Duties
« Reply #5 on: September 13, 2022, 10:33:48 am »
Our local Guards wouldn't pull you over if all your lights were gone.
I would keep working. A tax driver I know, has any amount of money, drove around for 3 months with a dip gone, too tight to replace it id say.
Re: Light Duties
« Reply #6 on: September 13, 2022, 10:35:34 am »
that's incredible. how does the bulbs last so long.
i don't know if its a quirk unique to my 2012 avensis but the two headlight bulbs always blew in unison.
they either go at the exact same time or one will blow and the other will go the next day.
pain in the nuts because they were 20 quid a pop each. 40 quid each time to do the both.
bought 20 bulbs for a wunner off ebay from a chink fella about 3 year ago.
delira i was. only in the last week or so have i exhausted the supply.
Re: Light Duties
« Reply #7 on: September 13, 2022, 10:40:33 am »
Its the Driver side you could look like a motorbike to oncomming traffic if they overtake in to your path they could make you dead or you jump into a ditch.
Re: Light Duties
« Reply #8 on: September 13, 2022, 10:47:47 am »
i have ocd. evertin hasta be symmetrical for me. i could'nt drive around with one blown bulb.
it i havva blown roof light(s) it irritates me.
Re: Light Duties
« Reply #9 on: September 13, 2022, 10:53:19 am »
What about odd socks ?Talking about OCD I have to have 35 euro in notes smaller than a score if I dont I will pull into a garage for a fivers worth of Diesel just to get change .
Re: Light Duties
« Reply #10 on: September 13, 2022, 10:54:06 am »
"that's incredible. how does the bulbs last so long?"
Dunno DMG I'm mostly ever only working the day shift but if it's raining or I'm in the bus lane passing traffic I'll put on the lights.My heap only has 296000Km.I think it's still on the original front shocks too so they're soft enough.My heap wouldn't vibrate like a diesel so that might be part of the reason for them lasting so long.
I've never changed a window regulator either but I always hear others doing stuff like that.In 300000 Kilometers it's only it's second set of front pads and they'll probably see it to the scrap yard.Never changed the rear brakes either.
It will probably explode tomorrow now that I've been going on about it...
Re: Light Duties
« Reply #11 on: September 13, 2022, 11:02:06 am »
how do the pads last that long.
do you drive like an aulwan or is it sumtin to do with the fancy breakin system.
Re: Light Duties
« Reply #12 on: September 13, 2022, 11:09:24 am »
I do drive a bit like an aulwan cos I like to give the passengers a limo experience...fast if I have to but generally not.
The pads still had meat on them at 250000Km.Changed them anyway with new discs as I had the thing apart.
Basically the pads don't engage until the vehicle goes below something like 10kmph.If you slam on for some reason they'll work but most of the normal braking is done by the magnets in the motor recuperating energy back to the battery.Very clever system that gives great economy.
Re: Light Duties
« Reply #13 on: September 13, 2022, 11:33:00 am »
Jumped into the car to go get a bulb and the lights all work .Must of been damp from all the rain .
Re: Light Duties
« Reply #14 on: September 13, 2022, 11:38:58 am »
FFS I'm after talking a load of bollox about hybrid power train systems for nothing....See if you can get the rubber cap off so it can dry out but it will go again when you least expect it..The joys of Renault ownership.
